Changing Default File Size Limit
Files that are sent via distributions in the WebApps Client have a default size of 30 mb. The following message is displayed if users attempt to send a file to their recipients greater than the default size limit.
Note: The second line of the message is generated by the Internet Information Services (IIS) server and its display is contingent on the IIS server version you are using, and other factors not related to the WebApps Client.
Before you begin
  • Determine whether a change is needed for the default file size limit.
  • Determine which file size will work best as a default for your company and its users.
Changing default file size limit
You can change the default file size limit by using IIS server > Configuration Editor.
To change the default file size limit
  1. Open IIS Manager. The Connections page appears.
  2. Expand the server name in the Connections pane, if necessary.
  3. Select Sites.
  4. Expand Default Web Site.
  5. Select AccuRoute.
  6. Go to Management on the AccuRoute Home page.
  7. Select Configuration Editor. The Configuration Editor page appears.
  8. Go to the Section drop-down list and select the down arrow.
  9. Select system.webServer.
  10. Select security.
  11. Select requestFiltering.
  12. Select requestLimits.
  13. Select maxAllowedContentLength.
  14. Change the default value to the new default.
  15. Select Apply in the Actions pane.
See the IIS Manager > Configuration Editor example below.
  1. Close IIS Manager.
Note: Changes made to the default file size limit apply to all Client and Device Client applications that are part of your workflow configuration.
Microsoft Documentation Resources
Request Limits Overview
Request Limits Element
About WebApps
