About the Server Upgrade
                                            The Server Upgrade topics contain instructions on upgrading your  server environment to the latest version of the
About AccuRoute
AccuRoute is Upland's award-winning document-handling platform that captures, converts, routes and archives both paper and electronic-based documents enabling fast, secure, simultaneous distribution of data to multiple destinations in multiple formats. Using AccuRoute, an organization can deliver information faster with more efficient work flows while reducing the cost, complexity and risk.
About the upgrade
The steps involved in upgrading a
- Preparing the current server for the upgrade.
 - Upgrading the following interfaces: Server, Remote Administrators, Remote Compose Components (Composers), Remote Connectors for DMS Libraries, Remote Embedded Directive Managers, Remote Modem Servers and clients.
 - Configuring the server if necessary.
Supported upgrade environment
The following sections list the supported operating systems, server, client, database and modem versions. Use the information as a checklist and ensure you have the supported versions before you start the upgrade.
Server Operating Systems
- Windows 2016 SP, 2019 64-bit
 - Windows 2012 R2 64-bit
Databases
- Microsoft® SQL Server 2012, 2014, 2016
 - Microsoft SQL Express 2012, 2014, 2016
Modem boards
- Dialogic® Brooktrout ® TR1034, SR140, or TruFax RoHS series with Boston v6.11.1+ drivers
Note: Dialogic Brooktrout board models that are older than those listed above are not supported.
Upland AccuRoute Server
- See Release Notes > Upgrade Support for the current versions the Server supports.
Client Operating Systems
- Microsoft Windows 10
 - Microsoft Windows 8.1
Upland AccuRoute Desktop
- Desktop client must be upgraded to the latest server version.
Upgrade Notes
All systems in your environment must use the same version of the server. Therefore, when you decide to upgrade your legacy server to the latest version, you must upgrade all systems that comprise your environment. This includes Remote Administrators, Remote Composers, Remote Connectors for DMS Libraries, Remote Embedded Directive Managers and Remote Modem Servers.
Note: Once you upgrade the server, all Remote Composers go off-line until you upgrade them.
If you are planning to set up and use ObjectArchive, verify that the system where you will install ObjectArchive meets the following hardware and software requirements.
- Windows NT domain computer that always runs in the same domain as the server
 - Dual core processor; 2 GHz; 4GB of RAM; RAID 5W with 100 GB of disk space; DVD-ROM drive; and Microsoft mouse or compatible pointing device
 - Windows 2012 64-bit, Windows 2008 R2 64 bit
 - Microsoft SQL Server 2012 or MS SQL Server 2008
Note: ObjectArchive must be installed on a system remote from the server. The SQL Server does not have to be the same one used for the server databases.
When you upgrade your server, you must upgrade all instances of the remote Intelligent Device Client in your environment. See Installing Intelligent Device Client for more information.
When you install the server as a new install, it creates one General Composer and one OCR Composer. This allows for the OCR Composer to be off-loaded more easily, freeing up valuable system resources.
However, when you upgrade from a legacy server to the latest server version, you may have only one instance of the Composer since the upgrade will not change your Composer configuration. You can add additional Composers, and configure a Composer to handle only OCR jobs.
Some prior versions of the Universal Output connector (the XML Output connector) are neither supported nor updated by this release. If you were previously using the XML Output connector, then after installing the upgrade you will need to manually enable the Universal Output connector and update any existing rules.
The installation setup files for the  clients are located in the Clients directory of the server. After you have finished installing the server, you must configure the Clients folder within the
Note: The Desktop Clients are supported by the server for one release back. Therefore, if you have Desktop Clients from the prior release deployed in your environment, upgrading them is not a requirement. However,
Upland AccuRoute is a cluster-aware application. If you plan to use the server cluster functionality after the upgrade, consult Setting up a Server Cluster section for an overview of the clustering functionality and instructions on setting up the cluster.
For Administrators planning an upgrade
Significant enhancements were made to RuleSets in the server upgrade v5.1. The following RuleSets issues have been reported after an upgrade.
- Empty rulesets, rules no longer exist
 - Disabled rulesets are enabled
 - Deleted rulesets reappear
 - Rules moved to different rulesets
 - Action items missing from rules
During the upgrade there is a conflict between the previous and current RuleSets tables and migrations that result in the issues listed above.
Note: Backup your server and database before upgrading.
Truncate Table RoutingRules Resolution
See the table below before using the Truncate Table Routing Rules resolution.
        Upgrade Scenario  |
        Truncate  |
        Server upgrade less than or equal to v5.0  |
        Do not truncate.  |
        Server upgrade from v5.1 to v5.1.1 or 6.x  |
        Truncating is required.  |
        Server upgrade from v5.1.1. to v6.x  |
        Server upgrade from v6.x to v6.x; for example, v6.0 to v6.2  |
- Open Microsoft SQL Server Management Studio and connect to the SQL server hosting the database.
 - Click New Query on the toolbar.
 - On the toolbar, change the database name on the drop-down list from Master to the Server’s Core Database.
 - Type the following query into the query window: Truncate Table RoutingRules.
 - Click Execute on the toolbar. Command(s) completed successfully message appears.
Note: If you have additional questions or require assistance in upgrading, contact Technical Support.
Companies have to manage Administrator rights to their technology resources effectively. Giving everyone in an organization Administrator rights is risky and can potentially result in a huge IT security breach and other technical issues. Operating system and other software applications have mechanisms in place that allow organizations to determine who can execute full or limited Administrator rights.
The server platform and its services support limited Administrator rights. You can set up limited Administrator rights for user accounts that need to perform specific server-related services. User accounts with limited Administrator rights cannot install or upgrade the server.
See Running the Server with Limited Administrator Rights for more information.
