Using Redaction
After Administrators have set up redaction, WebApps Security Station (SS) or Content Review (CR) users have the ability to redact and/or remove preselected redacted content in a document for legal and security purposes.
Note: SS and CR users are not removing physical content from a document. They are determining whether to redact (obscure) or remove the redaction flag from preselected content.
Redaction types
Allow redaction – review preselected redacted content. SS and CR users can choose to redact or remove the redaction. Click to redact is the default.
Redact – review auto-redacted (obscured) content areas. SS and CR users cannot choose to remove redaction.
Suggest redaction – review preselected redacted content. SS and CR users can choose to remove or redact content. Click to remove is the default.
More about redaction
Redactions are automatically saved and do not require a manual save.
Selecting or removing redactions for all preselected content is not required. Identify exceptions and click to redact or remove.
Documents that are approved or rejected are processed with manual, automatic, and/or preselected redactions. Documents cannot be retrieved to modify the redactions after they have been submitted.
The redaction process may take awhile. The following message appears: “Options being applied. Please wait.”
Redacting or removing redacted content
SS and CR users will use the following tools and actions to redact, select or remove redacted content.
Use the Redact button on the WebApps tool bar to manually draw and add redaction boxes to specific areas of a document.
Note: Redaction boxes cannot span across multiple pages. More than one redaction box must be used to select content that begins on one page and ends on another.
Press and drag any of the sizing handles to resize the redaction boxes, if necessary.
Press and drag the redaction box to move it to another area of the document, if necessary.
Use the x icon to delete the manually redacted boxes and start over, if necessary.
Click to redact or Click to remove to either redact or remove preselected redacted content in a document.
Allow redaction - Click to redact example
Redact - Obscured content, cannot be modified example
Suggest redaction - Click to remove redaction example
Note: The Click to redact and Click to remove labels will appear to assist Security Station and Content Review users during the redaction process.
