To add the WebApps Security Station
Expand the Server Administrator tree, if necessary.
Expand Configuration,
if necessary.
Select WebApps . WebApps details pane appears.
Select Default. The
Default Profile Properties dialog box appears.
Select the Applications
tab.
Click Add. The Applications
shortcut menu appears.
Select Messages > Security
Station.
Click OK.
Viewing
and/or troubleshooting redaction
To view the status of a redaction message
Use the Messages > In Process and History folders by selecting Messages
on the Server Administrator tree.
See the Messages > In Process folder example below.
See the Messages > In History folder example below.
See About Messages for more information.
To troubleshoot a redaction issue
Use the Journal on a redaction-related Server Administrator resource
by selecting the Journal tab that appears on the Properties dialog box;
for example, the Messages > History > Recipient Properties dialog
box.
The journal contains the history of a message. If any errors occur during
the processing of the message, they are listed in the journal. For example,
if you want to track the delivery status of a message, the message journal
can tell you if the message failed delivery and was resent at a later
time.
See the Messages > History > Recipient Properties > Journal
example below.
