About Custom Cleanup
The Maintenance component removes messages from the
Standard and Custom Cleanup Differences
Standard cleanup applies to all jobs
A standard cleanup can be configured between 3 and 180 days as a scheduled task on the Windows system where the server database is located. When cleanup runs, items are marked for deletion and deleted at 5 am the following day. This is a default setting that can be changed by an Administrator if necessary. Administrators use the Maintenance Component > Cleanup > Queues options to configure a standard cleanup.
Custom cleanup applies to specific jobs
A custom cleanup can be configured by setting cleanup job properties on a rule. This ensures that only specific jobs delivered by the rule are cleaned up by the Maintenance component.
The following System job properties can be applied to a rule to run a custom cleanup.
CustomCleanupEnabled
CustomCleanupIntervalHours
The following job properties can also be used in a control file.
prCustomCleanupEnabled
prCustomCleanupIntervalHours
Note: Jobs are flagged as expired based on the interval hour(s) set but are not removed until the scheduled maintenance has been completed.
Applying the Custom Cleanup Job Properties to a Rule
The following example shows how to apply the custom cleanup job properties to a Route to Connector rule.
Note: This example is for illustrative purposes and may not apply to your unique workflow requirements.
To apply the Custom Cleanup job properties to a rule
Create a user rule in the Server Administrator.
Select the user rule in the Details pane. The Rule Properties dialog box appears.
Select the Actions tab.
See the Rule Properties > Actions > Start Workflow action example below.
Select the Start Workflow action. The Action Properties dialog box appears.
Select the Job Properties tab.
Select the Add button. The Set Job Property dialog box appears.
Type CustomCleanupEnabled in the Property box.
Type 1 in the Value box.
Select OK.
Type CustomCleanupIntervalHours in the Property box.
Specify the number of hours, for example, 1 in the Value box.
Select OK on the Set Job Property dialog box.
Select OK on the Action Properties dialog box.
See the Action Properties > Job Properties > Custom Cleanup example below.
Select OK on the Rule Properties dialog box.
Indexing the CustomCleanupEnabled property
Indexing the CustomCleanupEnabled property Volume list may result in a faster cleanup. This step is optional but recommended.
To index the CustomCleanupEnabled property Volume list
Go to Job Properties in the Server Administrator.
Select System in the Details pane.
Select the CustomCleanupEnabled property. The Job Property dialog box appears.
Select the Indexing tab.
Select the Active Volume list.
Select OK.
Note: Jobs submitted after enabling indexing will result in a faster cleanup. Any jobs submitted before indexing was enabled will not.
