About MyFiles Document and Folder Control
Administrators can provide WebApps users more document and folder control of their My Files folder and any group folder they have access to.
Users can perform the following document and folder control tasks.
  • Mark read/unread documents
  • Rename documents
  • Add notes to documents (column setup required)
  • Create new, rename, and delete folders (folder support and permissions setup required)
  • Move (drag and drop) documents and folders
Note: The Notes column and create new, rename, and delete folders functionality require Administrator setup in the Server Administrator. The remaining functions are available as default settings when the WebApps is installed.
Before you begin
  • Install WebApps
  • Set up Notes column
  • Set up group folder support and permissions
About WebApps
About My Files
About Groups
About Folders
About RuleSets
Using My Files Document and Folder Control Options
