About Routing Sheets
Routing sheets always contain Embedded Directives information. An AccuRoute Desktop or Web Client user can generate a Routing Sheet containing the Embedded Directive information and add the Routing Sheet to an outbound message.
When the server generates a routing sheet on demand for an AccuRoute Desktop user, it creates an Embedded Directive, stores it on the server, and includes in the routing sheet. (This Embedded Directive acts like a "key", as it unlocks the routing information and processing instructions associated with the document.) When an outbound document includes a routing sheet containing an Embedded Directive, the server scans the text of the document (using OCR technology) and detects the Embedded Directive.
Routing Sheets are the result of two files.
  • Routing Sheet template - Can be in OMTPL, RTF, DOC, HTM, or HTML file format.
  • Routing Sheet display name - must be in the WTX file format and have the same name as the Routing Sheet template file.
Creating Routing Sheet Templates Guidelines
Routing Sheet Template Variables List
Supported Bar Codes
