About Zip Archive Connector
Connectors are used to manage how messages flow in and out of the AccuRoute Server. There are different types to meet the needs of your workflow requirements. Messages with attachments can be zipped and delivered to a specific folder with the use of the Zip Archive connector and rules.
In addition, Administrators can choose to set up how many times the server can attempt to deliver a message with attachments if the first attempt was unsuccessful. Error codes can also be set up to support Administrators in troubleshooting delivery failures.
Note: A license is required for the Zip Archive connector. Contact your Account Manager if necessary. Auto Retry and Error code setup are optional and not required for Zip Archive connector use.
Before you begin
  • Obtain and activate the Zip Archive connector license.
  • Determine where to deliver the zipped attachments.
  • Determine whether Auto Retry and Error codes are to be used (optional).
  • Set up the Zip Archive connector.
  • Create a Route to Connector rule.
  • Set up Zip Archive folder maintenance and cleanup.
Accessing Connectors
You can access any connector to view and edit its properties by using the Server Administrator > Connectors node.
To access Connectors
  3. Select Connectors. The Connectors details pane lists the connectors that are licensed with your server.
  4. Select any connector to view and edit its properties if necessary.
The following instructions show how to set up the Zip Archive connector with Auto Retry and Error codes.
Note: These instructions are for illustrative purposes and may not reflect your unique workflow requirements.
About Connectors
About RuleSets
About Messages
About Maintenance Component
