Adding a Summation Connector
Before you add the Summation connector, verify that you meet all the requirements listed in Summation connector requirements. You must also configure DCOM and change the logon account for the AccuRoute Connector Manager. For configuration instructions, see Required Summation Connector Configurations.
To add the Summation connector
  3. Right click Connectors. Select New > SSR Connector. The License dialog box appears.
  4. Enter the license number.
  5. Click Next. The Server Address dialog box appears.
  6. Click Next. The Display Name dialog box appears.
    Alternately, if you want the connector to run on a remote server, click Remote Server and enter the server name. Click Next.
  7. In the Name box, enter an appropriate name.
  8. Click Next. The Congratulations dialog box appears.
  9. Click Finish. The summation connector is listed in the details pane.
About Summation Connector
Configuring Summation Web Integration Environment
Using Summation iBlaze
