Configuring Summation Web Integration Environment
Several files are used when you install the Upland AccuRoute Summation Add-on Client. Edit the following configuration files before installing the Summation Add-on Client.
  • Configuration.xml file
  • Registered User settings in the Server Administrator
About Summation Connector
Required Summation Connector Configurations
Adding a Summation Connector
Using Summation iBlaze
