How to Configure the West km Connector
All BA Insight connectors can be downloaded from Right Answers under Knowledge > BA Insight > Product Downloads > Connectors.
This connector is installed with the same generic steps as any BA Insight connector.
Satisfy the Prerequisites for your connector before installing.
Configuration specifics are detailed below.
How to Configure West KM Connector
Add the Component West KM Metadata.
Click Existing Components to see the Configuration section:
Elastic Server Address:
Specify the Elastic Server Address
All Elastic v6.x versions are supported
Click Validate:
User and Password fields may be required if Elastic is secured.
User Id:
Provide your Elasticsearch User ID, if required.
User Password:
Provide your Elasticsearch user password, if required.
Timeout:
Provider desire Timeout.
Default: 30
Load/Select Index:
Select the desired West km index for vetted documents
Metadata Property:
Enter metadata property to match the Elastic document.
Typically, DocumentId
Index Key Field:
Enter elastic document number index field.
Typically, doc_num
Include Cite Recognition:
Select this option to include Cite Recognition data
Include Classification:
Select this option to include Classification data
Litigation Properties:
Enter litigation properties, semi-colon separated, to retrieve as metadata from the Elastic Index.
Leave empty to ignore litigation properties.
Configuration defaults standard West Metadata fields
Include Unresolved Litigation Properties:
Select this option to include metadata that West KM has extracted but are not fully resolved by West KM.
Transactional Properties:
Enter transaction properties, semi-colon separated, to retrieve as metadata from the Elastic Index.
Output Properties
Classification Properties
| Property | Type |
| WKMClassification | Text – Multi |
Citation Properties
| Property | Type | Description |
| WKMCitation | Text – Multi | Citation Title |
| WKMCitationLink | Text – Multi | Delimited Citation field for UI display. Separator: "|" Format: Citation Title|Citation Normalized|Cite Publication|Cite Serial Number|Cite Summary if available |
| WKMCiteNormalized | Text – Multi | Citation Title without special characters |
| WKMCitePublication | Text – Multi | Citation Publication Number |
| WKMCiteSerialNumber | Text – Multi | Citation Serial Number |
Transaction Properties are dynamic based on input properties.
Default Properties:
law_firm_name;attorney;party;governing_law
Example:
law_firm_name when detected returns WKMTransLawFirmName
| West km Property | Property | Type |
| law_firm_name | WKMTransLawFirmName | Text – Multi |
| attorney | WKMTransAttorney | Text – Multi |
| party | WKMTransParty | Text – Multi |
| governing_law | WKMTransGoverningLaw | Text – Multi |
Litigation properties are dynamic, based on input properties.
Default Properties:
company.name;expert_witness.name;law_firm.name;judge_primary.name;judge_secondary.name;attorney.name;document_type.name
| company.name | WKMLitCompanyName | Text – Multi |
| expert_witness.name | WKMLitExpertWitnessName | Text – Multi |
| law_firm.name | WKMLitLawFirmName | Text – Multi |
| judge_primary.name | WKMJudgePrimaryName | Text – Multi |
| judge_secondary.name | WKMJudgeSecondaryName | Text – Multi |
| attorney.name | WKMAttorneyName | Text – Multi |
| document_type.name | WKMDocumentType | Text – Multi |
Note: Transaction properties can be combined for UI display purposes.
Example
company.name|company.url
Return Property WKMLitCompanyName: ACME|http://www.westlaw.com/......
Including Additional Properties
Additional Elastic Properties can be included.
Use Elastic to search for a document
Download the JSON Results
The JSON results are flattened
litigation_metadata.company.westlaw_id = 2883123
litigation_metadata.company.name = Capital Trade
litigation_metadata.company.id = 2fffabf0-e33b-4ae8-a1a8-143acd501ed6
litigation_metadata.company.url = http://www.westlaw.com/Search/Results.html?query=advanced%3a+WCAID(I48F4449042B311DDA5520014224D2780)&jurisdiction=ALLCASES&saveJuris=False&contentType=BUSINESS-INVESTIGATOR&startIndex=1&contextData=(sc.Default)&categoryPageUrl=Home%2fCompanyInvestigator&originationContext=document&transitionType=DocumentItem&vr=3.0&RS=wlw
