Define Content Security
Use the Content Security form to configure how security is applied to your item.
If you are using the Active Directory mapped model and have already synchronized your users and groups, then you must at minimum fill in the Grant SQL statements to ensure that your ACLs are built properly.
The real-time security trimmer section can be utilized in any model, but please read Search Security for approaches.
  1. In The Framework Admin Console select the Content tab.
  2. On the Content Management page select your SQL Content Source.
  3. Click the Security tab.
  4. Public Flag: Choose the column that indicates whether content is publicly visible. Any value or column that contains 1, -1, t, true, y, or yes evaluate to public, and entering true marks all as public. Leave blank if none are public. The effect of an item being marked as public can vary depending on whether you have created an 'All Users Group'. SeeHow to Configure Active Directory for Your Connector.
  5. User Grant SQL: Enter the SQL statement that returns the list of user IDs that have permission to access this item.
    • SPW_USERID: Required column.
    • [SPW_ID]: Required parameter.
    • [SPW_SUBID]: Optional parameter.
    • Place the character @S_ or @I_ in front of a variable to indicate String or Integer value. For example, @S_SPWID.
  6. User Deny SQL: Enter the SQL statement that returns user IDs of users that are specifically denied access to the system.
  7. Group Grant SQL:
    Enter SQL Statement that returns group IDs of groups or roles that have permission to access the item.
    • SPW_GROUPID: Required column.
  8. Group Deny SQL:
    Enter the SQL statement that returns the list of group IDs that are specifically denied access to this item.
    This overrides Grants.
    • SPW_GROUPID is a required column.
    • [SPW_ID] is a required parameter.
    • [SPW_SUBID] is an optional parameter.
      • For example, @S_SPWID.
  9. ACL Script:
    1. Enter VBScript to override or modify the security attributes of the item.
    2. In this script you can add/remove users and groups from the list of granted or denied users.
    3. You have access to all the items datasets in the script for more complex analysis.
    4. For more information, see VB.Net Scripting.
  10. Enabled Real Time Security: Check the box if real time security is enabled. When this box is checked, Real Time Security SQL becomes a required entry (see next item).
  11. Real Time Security SQL:
    1. This is a required field when real time security is enabled.
    2. Enter the SQL statement that returns a result if the user is granted access to the item based on the passed in item ID and resolved user ID.
    3. The value returned does not matter, only the fact that it returned a record.
    4. Using this model alone results in a single query per item being run.
      • Parameters:
        • [SPW_ID], (required)
        • [SPW_SUBID], (optional)
        • [SPW_USERID], (optional)
  12. Use this field to provide a custom VB.NET script you can override the default functionality of the real time trimmer and execute the SQL Statements in a more efficient batched way.
    1. You can also perform real analysis of returned values to determine whether a user is granted access to items or not.
    2. The global variable HOST is accessible throughout the script to provide various functions.
      Sample
      This checks the security by running a SQL statement in batch mode for items.
      Copy
      Dim sIm()() As String = HOST.GetSecurityItems()
      Dim sqlString As String = HOST. GetSecuritySQL()
      For i As Integer = 0 To sIm.Length - 1
      Dim docId As String = sIm(i)(0
      Dim docVer As String = sIm(i)(1)
      dim tSQL as String = sqlString.Replace("[SPW_ID]",docId). Replace
       ("[SPW_SUBID]",docVer).Replace("[SPW_USERID]", HOST.GetResolvedUserID())
      HOST.WriteTrace("SCRIPTSQL:" & tSQL)
      dim ds as Dataset = HOST.FillDataSet(tSQL)
      If (ds.Tables.Count 0 AndAlso ds.Tables(0).Rows.Count > 0) Then
      Dim fail As Boolean = False
      For ii As Integer = 0 To ds.Tables(0).Rows.Count - 1
      If (ds.Tables(0).Rows(ii).Item(0).ToString() = "0") Then
       fail = True
      Exit For
      End If
      Next
      If Not fail Then
      HOST.GrantItemAccess(docId, docVer)
      End If
      End If
      Next
      For more information, refer to VB.Net Scripting
  13. Click Save.
