SharePoint Online O365 Connector Prerequisites
For the authentication mechanism-specific requirements, see the following pages:
| SharePoint version | O365 |
| Searchable content types | Yes | The SharePoint Online connector enables you to connect to SharePoint Online, fetch data from any site, document library, or list; and index this content securely. |
| Content Update | Full and Incremental | All BA Insight Connectors support both Full and Incremental crawls, unless noted. |
| Permission Types | Yes | All BA Insight Connectors support fetch ACLs from the source system. To make items public or restricted to a single user or set of users, you can do so within the Connector Framework. |
| Required Software |
.NET Framework v4.7.2 SharePoint Azure App Certificate |
A SharePoint Online Azure App must be registered with Azure and must have permissions as described in the table below. A certificate-based authentication, a certificate is required.
| Required Permission | Description |
| Azure |
You must have access to the Azure Portal site and sufficient permissions to create and mange Azure app registrations. |
| Azure App permissions |
The SharePoint Online connector supports both authentication mechanisms: The permissions required for each mechanism is detailed bellow |
| Windows | The account used to run the connector must be a local Administrator on the server and cannot be any of the built-in service accounts (NetworkServicelocal machine, etc.) |
Government Clients
For Government clients employing Azure AD, you must make small changes within your Web.config file.
See How to Configure the SharePoint Online Connector Using Web.config.
