How to Personalize User Queries
About Personalized Queries
Personalized queries are used to filter and boost search results.
This can be done one of the two ways:
Be aware that the order of relevancy stages order can impact the way documents are boosted.
The default priority order is:
  1. User Relevancy
  2. Personalization
  3. Admin Relevancy
Limitations
Some SmartHub Features are unsupported by some backends.
For information about limitations to your backend, see the "Limitations" topic for your backend.
Personalized Query Pipeline Stage
  • The Personalized Query pipeline stage enables you to append information to an actively running user query.
  • This stage requires you to set the User Profile settings.
    • The appended information is generated based on the users’ User Profile properties such as Department or JobName.
  • Use the steps in Add a scripting stage to add the Personalized Query stage.
Personalized Query Stage Parameters
UI Elements Description
First match (toggle) Enables the query processing stops at the first match per keyword
Keyword (value)
Enables the user to specify the keyword. This field is required.
Included Result Sources
Enables the user to specify what result sources are used.
If multiple result sources are used, the values must be separated by a semicolon.
Excluded Result Sources
Enables the user to specify what result sources are excluded.
Type Enables the user to select the keyword type.
New Keyword (button) Creates a new keyword with all the properties associated to a keyword.
Delete Keyword (button) Deletes the selected keyword.
Partial Match A toggle that enables partial matching.
Addition Group of parameters described in bulleted list below.  Can be added or removed (with red 'X').
  • Condition property
The user can specify a property that is used in the condition check for the addition.
  • Condition value
The user can specify the condition check value for the addition.
The addition condition is formed from the condition property and the condition value.
  • Operator
Has one of the two available values: "AND" / "OR" . The default value is "OR".
  • Multivalue operator
  • Multivalue delimiter
Enables the user to specify a delimiter for multivalue properties. The input is invalid if it is empty.
  • Property format
Enables the user to specify an additional property format.
Examples:
XRANK(cb = 100) {0}.
ESC_DEPARTMENT. Shown in the example below this table.
Generate property format value button
Shown in the example graphic below. When clicked, this button renders a number of property values inputs based on the number of properties used in the property format text box.
The property values are rendered in the order used in the property format textbox.
  • Property format value
(can appear multiple times)
Enables the user to specify the value for the property used in the property format textbox.
  • Property default value
Enables the user to specify a default value that is used in case that the dynamic property value entered does not exist.
  • Delete addition
Deletes the selected addition.
  • Sorting
Enables the user to reorder the additions.
  • New addition
See button at bottom of graphic below. Creates a new addition with all the properties associated with an addition.
Personalize Query Keyword Example
See the following graphic for examples of various Personalized Query pipeline stage parameter values.
