Prerequisites: SmartHub with Azure Cognitive Search
Installation Prerequisite Checklist
Requirement |
Description |
Completed |
| SmartHub Server | |||
Operating System | Microsoft Windows Server
| Windows Roles and Features | Must have Web Server(IIS) role enabled with the following Roles and Features selected:
| .NET Framework |
Service Account (domain\user) |
Local or network service account used to run the SmartHub Application pool in IIS
Account credentials: (domain\user) |
Installation Account (domain\user) |
Account used to install SmartHub
| Supported Web Browsers | |||
*Unsupported Web Browsers Other web browsers may work with SmartHub, such as:
These browsers are not officially supported by BA Insight. |
| Analytics Index | |||
Elasticsearch v7.10 |
Secured or non-secured Elastic configurations supported. Note: The Elasticsearch index used for the SmartHub data does not have to be the same instance use for the search index (backend). Note: Elasticsearch requires Java JDK. Elasticsearch v7.x and later bundles Java with the software (OpenJDK). A separate Java download/install is NOT required. For assistance installing a single-node instance of elastic, see: How to Install Elasticsearch for Analytics |
Elasticsearch URL: Elasticsearch Username: Elasticsearch Password: |
| Kibana v7.10 |
Kibana must be configured to use the above Elasticsearch index. Supports secured or non-secured Kibana configurations For assistance installing Kibana and running as a windows service, see: How to Install Elasticsearch for Analytics |
Kibana URL: Kibana Username: Kibana Password: |
| NLQ Services (Optional) | |||
LUIS (v2 API) RASA v1.9 Lex CLU |
Only one NLQ service should be configured. Supported NLQ/AI Engines: For more information see: |
Service Endpoint:
Service Key (LUIS only): |
| Search Engine | |||
Azure Cognitive Search |
SmartHub v6.0 supports Azure Cognitive Search as a search index. Before you integrate your Azure Cognitive Search Backend with SmartHub you must satisfy the following requirements:
Azure Index Limitation
In SmartHub you must configure one backend for every Azure Cognitive Search index you intend to query. |
Azure Cognitive Search URL: Azure Cognitive Search Username: Azure Cognitive Search Password: |
| Network Requirements | |||
DNS entry for SmartHub site |
This can be either an internal, or an external (public) DNS entry. Entry can point to VIP / F5 / Load Balancer / other network device. Requests should be routed to IIS on the SmartHub server over the chosen ports. |
DNS name / URL for SmartHub: |
| SSL Certificate | If running SmartHub over SSL (recommended), a signed SSL certificate for that DNS name (or appropriate wildcard cert) is required. |
Certificate name: Pass-phrase (if required): |
Internal Network Connectivity |
The SmartHub server must have network connectivity to the following:
Verified:
| External Network Connectivity | Network connectivity from the SmartHub server to the following Microsoft Azure services is required if you use the service(s):
Verified:
