Prerequisites: SmartHub with SharePoint Online
Deployment Topology
The following is an example of SmartHub as it lives within a network topology.
Installation Prerequisite Checklist
Requirement
Description
Completed
SmartHub Server
Operating System
Microsoft Windows Server
  • 2012 and 2012 R2: 64-bit
  • 2016
  • 2019
  • 2022
  • (Complete)
Windows Roles and Features Must have Web Server(IIS) role enabled with the following Roles selected:
  • Common HTTP Features
  • Health and Diagnostics
  • Performance
  • Security
  • Application Development
    • .NET 3.5
    • .NET 4.6
      • ISAPI Extensions
      • ISAPI Filters
      • WCF Services
        • HTTP Activation
  • .NET Framework 4.6 Features
    • WCF Services
      • HTTP Activation
  • (Complete)
.NET Framework
  • .NET Framework v4.7.2 required for Windows Server versions: 2012, 2016, 2019
  • .NET Framework v4.8 required for Windows Server 2022 (included with Windows and used automatically, by default)
  • (Complete)
Service Account (domain\user)
Local or network service account used to run the SmartHub Application pool in IIS
  • Must be in the format domain\user
  • Requires read/write access to the directory SmartHub is installed in.
Account credentials: (domain\user)
Installation Account (domain\user)
Account used to install SmartHub
  • Must be local admin on machine
Supported Web Browsers
  • Google Chrome
  • Microsoft Internet Explorer v11
  • Other browsers unsupported*
*Unsupported Web Browsers
You may find other web browsers, such as Microsoft Edge, Firefox, Safari, etc work with SmartHub.
These browsers have not been tested and are not officially supported.
Analytics Index
Elasticsearch 7.10
Secured or non-secured Elastic configurations supported.
Note: The Elasticsearch index used for the SmartHub data does not have to be the same instance use for the search index (backend).
For assistance installing a single-node instance of elastic, see: How to Install Elasticsearch for Analytics
Elasticsearch URL:
ElasticSearch Username:
ElasticSerach Password:
Kibana 7.10
Kibana must be configured to use the above Elasticsearch index.
Supports secured or non-secured Kibana configurations
For assistance installing Kibana and running as a windows service, see: How to Install Kibana for Analytics
Kibana URL:
Kibana Username:
Kibana Password:
NLQ Services (Optional)
LUIS (v2 API)
OR
RASA v1.9
Only one NLQ service should be configured.
Supported NLQ/AI Engines:
  • LUIS - Access to a LUIS instance if using the NLQ feature
  • RASA
For more information see:
Service Endpoint:
Service Key (LUIS only):
Search Engine
SharePoint Online
SmartHub supports SharePoint Online as a search index.
SharePoint Online URL:
SharePoint Online Username:
SharePoint Online Password:
Network Requirements
DNS entry for SmartHub site
This can be either an internal, or an external (public) DNS entry.
Entry can point to VIP / F5 / Load Balancer / other network device.
Requests should be routed to IIS on the SmartHub server over the chosen ports.
DNS name / URL for SmartHub:
SSL Certificate If running SmartHub over SSL (recommended), a signed SSL certificate for that DNS name (or appropriate wildcard cert) is required.
Certificate name:
Passphrase (if required):
Internal Network Connectivity
The SmartHub server must have network connectivity to the following:
  • Analytics Index
  • Search Index
  • RASA NLQ Service (optional)
Verified:
  • Elasticsearch service (see Analytics Index, above)
  • Kibana service (see Analytics Index, above)
  • Search Index
External Network Connectivity Network connectivity from the SmartHub server to the following Microsoft Azure services is required if you use the service(s):
Verified:
  • AzureAD (optional)
  • SPO / Graph API (optional)
  • LUIS NLQ Service (optional)
