iManage AppBus Plug-in for AutoClassifier
About
The iManage AppBus Plug-in for AutoClassifier integrates the AutoClassifier processing pipeline capabilities with the iManage source system.
Metadata created via an AutoClassifier processing pipeline is pushed directly into iManage documents' properties.
Prerequisites
  • AutoClassifier iManage Plug-in
    1. Download the BA Insight iManage Plug-in for AutoClassifier .zip file from the Upland Right Answers Portal (requires login).
    2. Save the .zip file to a location accessible by AppBus Studio
How to Publish the iManage Plug-in
  1. Open AppBus Studio.
  2. Select File → Open.
  3. Select the iManageACPlugin project folder and open the asln file.
  4. From the left side, from Projects, select iManageACPlugin.See below.
  5. From the above menu, select View → Panels → Properties.
  6. On the right side, a properties dialogue box appears.
  7. Enter a name in the Environments field, and press the '+' button.
  8. Enter
    1. URL:
      1. Enter the URL of your AppBus Server API Endpoint. To find this:
        1. Login to the AppBus Server UI.
        2. Go to the "Management API" in the left navigation.
        3. Find the "Computed URL".
        4. Use this value. For example: https://appbus-api.test.local/v1
    2. User:
      1. Enter the AppBus Cloud Tenant access user in the format name@domain.com.
      2. See the example above.
      3. Acquire this information from BA Insight Support team.
  9. From the left side, right-click on iManageACPlugin and select Publish from the sub-menu that appears.
  10. A pop-up appears.
  11. From the drop-down menu, select your Environment, add a Password into the field shown, and click Confirm.
  12. Access your AppBus Server Tenant in your browser.
    For example: https://demo.appbuscloud.com/
  13. Select Projects.
  14. Search for your published Project
    1. This is the name from AppBus Studio - iManageACPlugin
  15. Select the Project.
  16. Click the Deploy button and wait for a few seconds.
  17. Now you are ready to use the plug-in.
  18. Use the steps below for more information about how to use the iManage plug-in for AutoClassifier.
How to Use the iManage Plug-in
  1. From the Appbus Cloud address go to Projects:
    • Example: https://demo.appbuscloud.com/projects
  2. Search for and click on iManageACPlugin.
  3. Select SECRETS button from the right side.
  4. Select and edit each option from the menu:
    1. clientId
    2. clientSecret
    3. password
    4. username
  5. The values from each field must be completed with the values received from iManage.
  6. After each option from Secret has been updated, go back to iManageACPlugin.
  7. Select API SPEC.
  8. Select /api/101/153/iManageACPlugin
  9. Select "Try it out."
  10. Complete all parameters.
  11. Click Execute.
Optional
Schedule
This option can be used in order to schedule an incremental crawl.
  1. Select /api/101/153/iManageACPlugin
  2. Select Schedule.
  3. Complete all the requested parameters and set the isIncrementalCrawl parameter to true
  4. Complete the parameters and the scheduled time when the plug-in is to run.
  5. Click Add.
Set Timeout
Default timeout is set to 600 seconds.
The timeout can be changed from AppBus Cloud.
  1. Click the Edit button near the logs button.
  2. API Timeout (in seconds) appears.
  3. Set this value as you desire.
Parameters
  • RequestUrl
    • iManage address.
    • Example: https://cloudimanage.com
  • LibraryId
    • iManage library used to get the documents.
    • Example: Active
  • AutoClassifierAdress
    • AC installation address
    • Example: http://localhost:1967
  • Filter
    • iManage filter for documents:
    • Example: type=ACROBAT
    • Check the list with the filterable properties.
  • PageSize
    • Represents how many items receive pre-requests from iManage.
    • Default value: 25
  • Token ExpirationTime
    • How many minutes must remain until access_token is refreshed
    • Default value: 20
  • isIncrementalCrawl
    • If set to true:
      • A filter is added to the request
      • The items returned are only those files changed since the last crawl
    • Default value: false
  • ContentFilter
    • Using this field, choose which Workspace/Folder from the iManage source system to update
    • Workspaces must be separated by the character ';'
    • Workspaces and Folders must be separated by the character '/'
    • Folders must be separated by the character '#'
    • Note: To update all of the folders inside a workspace,
      • Add only Workspaces
      • Example:
        • WorkspaceName;WorkspaceName2;WorkspaceName3
  • Note ContentFilter
    • If you want (some) specific workspaces and (some) specific folders from a workspace:
      • Use the format:
        • WorkspaceName/FolderName#FolderName;WorspaceName2/FolderName;WorkspaceName3;
  • CallerId
    • Represents an identifier that is passed to AC as one of the properties in order to use as filter in AC configuration.
    • See Example 3 below
    • Output property: iManageCallerId
Metadata
  • AutoClassifier can push processed values to the properties available in the iManage search schema.
    • The names of the properties in iManage are standard types.
  • You must configure AutoClassifier to return metadata with the same exact property name to be populated.
    • Example: "custom10"
To re-name AutoClassifier output properties to match the iManage search schema, use the scripting stage with scripts as in the examples below.
  • The scripting stage must be the last stage in your processing pipeline.
Example 1: For single-value text properties
Copy
var singleValueText = item.Get<string>("Language");
if(!string.IsNullOrEmpty(singleValueText))
     item.Set<string>("custom10", singleValueText);
Example 2: For multi-valued text properties
Copy
var entitiesMulti = item.Get<List<string>>("MicrosoftExtractedEntities");
if(entitiesMulti != null && entitiesMulti.Any() )
     item.Set<List<string>>("custom11", entitiesMulti);
Example 3: Setup trigger based on the iManageCallerId
Copy
var callerId = item.Get<string>("iManageCallerId");
if(callerId.Equals("ExpectedValue")){
    return true;
else {
    return false;
See the screenshot below:
Scheduling Requests via Windows Task Scheduler
If you need a basic task scheduler to invoke some operations served by your web API, use the following methodology for recurrent tasks by using both:
  • RESTful API (ASP.Net WebApi application)
  • Windows Task Scheduler
Use the following steps:
  1. Create the PowerShell script file (file type is ps1).
  2. Add invoke code such as:
    Copy
    Invoke-WebRequest -Headers @{"Authorization" = "Basic ???"} -ContentType application/json -Method POST -Uri https://???/task/sample
  3. Create a basic scheduled task and to the program field call the script file like this:
    Copy
    powershell -command "C:\_Task\Sample_Hourly.ps1"
NOTE: Running PowerShell scripts requires the execution policy is changed to unrestricted.
Use the following command to make this change:
Copy
powershell.exe -command set-executionpolicy unrestricted
Limitations
Due to iManage limitations:
  • If you need to assign a multi-value property from AutoClassifier to a property from iManage:
    • The plug-in takes each value from the mult-value property and consolidates them into a string using the “;” character as a deliminator.
Also note the following:
  • Following items cannot be updated:
    • Two workspaces of the same name.
    • Two folders with the same name from the same workspace.
  • To update properties from AutoClassifier:
    • AutoClassifier properties must have the same name as the properties from iManage.
    • For example:
      • To update property “custom10” from iManage, AutoClassifier must also return the property “custom10”.
      • NOTE: Properties are case-sensitive.
Metadata Limitations
  • custom1-12:
    • 32 characters
  • custom13-16:
    • 96 characters
  • custom29-30:
    • 32 characters
Managing Document Properties
The following fields are read only:
  • Document Type
  • Document number
  • Document size
  • Version number
  • Created
  • Modified
  • Status
  • Checkout Location
  • Location
  • Related Documents
The following fields can be edited depending on the permissions granted to you:
  • Document name
  • Author
  • Comments
  • Class
  • Operator
  • Security Details
  • Any additional document properties displayed
Note: When AutoClassifier updates iManage documents, the document Modified date does not change.
