How to Extract Metadata from PACER Documents
- About the PACER Metadata Extractor Component
- How to Add the PACER Metadata Extractor to AutoClassifier
- How to Configure the PACER Metadata Extractor Component
The PACER Metadata Extractor pipeline stage extracts legal information from Pacer documents.
Prerequisites: This component needs Tika Extractor Component.
Use the following steps to add the Tika Extractor Component and Pacer Metadata Extractor Component to an AutoClassifier pipeline stage.
- Navigate to the AutoClassifier Pipelines component page.
- Click New Component and select Tika Extractor from the component list:
- Name your new Tika Extractor component and clickAdd.
- Select PACER Metadata Extractor from the component list:
- Name your new PACER Metadata Extractor component and clickAdd.
- Click Apply to save your changes.
- Ensure your new Tika Extractor and PACER Metadata Extractor components are placedin the list of existing pipeline stages.
Prerequisites: The Tika Extractor Component must be configured.
- Open your Tika Extractor component.
- Check Extract Body and Extract Metadata.
- Click Apply then Cancel.
- Open your PACER Metadata Extractor component.
- Enable Court Listener Mappings: Represents whether the output will contain the CourtId and CourtName equivalent to CourtListener API.
- If this setting is enabled, PacerCourtId, PacerCourtName, CourtListenerCourtId, and CourtListenerCourtName are dislpayed instead of CourtName.
- Enable Extracting Judge Name: Represents whether the output will contain the judge name.
- If this setting will be enabled, the Judge will be displayed.
- Extract Judge Names Regex Pattern: Represents the Regex that will match the words before the judge name.
- Example: hon\.|honorable|district judge
Output Properties
Property
Type
Type Text
PublishDate Text
DocumentDisplayNumber Text CourtName Text Cost Text CaseName Text CaseId Text PacerCourtId* Text PacerCourtName* Text CourtListenerCourtId* Text CourtListenerCourtName* Text Judge** Text *Note: PacerCourtId, PacerCourtName, CourtListenerCourtId, CourtListenerCourtName metadata properties are returned only if "Enable Court Listener Mappings" is set to True. In that case, CourtName is not returned.
**Note: Judge metadata property is returned only if Enable Extracting Judge Name is set to True.
