Configure Online Add-In App Package
Note: This step only applies when using the High Trust Security Model
Procedure:
Expand the app Add-In Package option:
- App Title: This is pre-populated from the Certificate Friendly Name.
- App Client Id: This is pre-populated and is the same as Issuer ID. This value must be used when registering the SharePoint Add-In App.
- Select App Package:
Choose between:- Classic: This is SharePoint Classic UI
- Modern: This is the SharePoint Modern UI
- Search Tags: This is a minimal UI without Menu Options
- Package the App. This packaged Add-In App is loaded into SharePoint in later documentation topics.
- Copy the download to a different location, if desired.
- Continue to the next topic.
