How to Override Item level Security Using ACL Scripting
Access Control List Scripts
Common usage scenarios include providing access to public or approved documents.
Use this operation with content such as:
Secure SQL-based content
Documentum content
Template content
You can also see this field in the Content Services > Advanced tab when you select
WebService Content.
To access the ACL Script field where you can enter your script, follow these steps:
- Go to Content Source > Edit > Advanced.
- Scroll down to see the Filter script and ACL script boxes.
- Enter your script using the information that is in this section.
- Compile: Click to validate and use your script.
Tip: If you choose Edit in designer, a text editor appears that lets you enter and compile your script.
For a list of available access control scripts, functions and description of them, see Security Scripts and Functions.
