Adobe Experience Manager connector release notes
The respective releases of the Adobe Experience Manager connector feature the following enhancements. For more information about the connector, see About the Adobe Experience Manager Connector.
Adobe Experience Manager Connector 1.0.4.0
System enhancements
| Issue | Description |
| Support for renditions in Adobe Experience Manager assets |
The Adobe Experience Manager connector now supports asset renditions. These are customized versions of digital assets, such as images, designed for different devices and platforms to ensure optimal performance. As a result the following advanced settings have been added:
For more information, see Set Up and Configure the Adobe Experience Manager Connector. |
Fixed issues
If a folder was deleted in Adobe Experience Manager, during the next crawl, the folder was not able to deleted in Connectivity Hub if the file path name was excessively long. (1816172)
Adobe Experience Manager Connector 1.0.3.0
System enhancements
| Indexing enhancements | The Adobe Experience Manager connector now supports indexing assets that are associated with a digital rights asset management license to specify the terms and the duration of use of the asset. For more information, see Digital Rights Management for digital assets in the Adobe documentation. |
Fixed issues
If an asset was associated with a digital rights asset management license, the Adobe Experience Manager connector would index the statement for the license rather than the asset itself. (BAI-17263)
Adobe Experience Manager Connector 1.0.2.0
System enhancements
There are no system enhancements in this release.
Fixed issues
Deleted items in Adobe Experience Manager would return errors in the logs during a Connectivity Hub crawl. (BAI-16544)
Adobe Experience Manager Connector 1.0.1.0
System enhancements
| Feature | Description |
| Custom filter enhancements | Custom filters are now specified in the advanced settings of the connection Connection defines the how Connectivity Hub connects to your Source System (which contains your documents, graphics, etc.,). Your Connection includes identifying elements such as: URL of the BA Insight web service connector you are using, (File Share connector, SharePoint Online connector, etc.), Authentication mode, User Accounts and Credentials, Database information (for database connectors) configuration. Previously, custom filters for Adobe Experience Manager pages and assets were applied at the root-folder level only. For more information, see How to Set Up and Configure the Adobe Experience Manager Connector. |
| Date logic improvements | New logic was implemented to determine the "last modified" date of an asset or page in Adobe Experience Manager (AEM). The AEM connector uses the following date attributes to identify modified items during an incremental crawl Scanning and capturing only new data from all of your content sources. This data did not exist when the last crawl was run.:
The most recent date is now used as the "last modified" date when updating the index. |
| JSON output improvements | In the JSON collected by the AEM connector, only the first instance of a property or parameter name is collected. As a result, the jcr:created parameter of the jcr:content property has been renamed to jcr:contentcreated to ensure that the value is retrieved. Previously, only the jcr:created property value at the root-level was retrieved. |
Fixed issues
There are no fixed issues in this release.
