Deploy Your Confluence Connector
Confluence Data Center Connector
When the Web service URL is specified, click Connect or Refresh Web Service in order to access a drop-down list of actions that the selected connector mode can use.
Specify your settings based on the mode that you chose in the Confluence Connector Prerequisites section.
Note: You must create the database user and grant them access to all the tables for either the REST API + SQL Server or the REST API + PostgreSql modes.
Confluence Connection Settings for REST API Mode
- Password: Certificate password, as specified in the Generate the Authorization Token topic.
- Confluence URL: Use this URL in Web browsers to reach the Confluence UI.
- Get users by Group Name: This specifies the name of the group used by the security sync job Loads User and Group tables and executes the mapping based on the connector configuration. to gather information about the users. This should be left empty if less than 10,000 users exist.
- Return labels as metadata Provides context with details such as the source, type, owner, and relationships to other data sets. Metadata provides details around the item being crawled by Connectivity Hub.: If this option is enabled, labels are returned in a custom metadata property. Use this setting only if required due to performance impact. This impact is because an extra API call is required.
- Return all items as public: This setting skips the permission check for the crawled items in the search index Contains data from your source system. Your search application instance (Elasticsearch, SharePoint Online, etc.) contains the search indexes. One search index per content source.. For this reason, all of the users have access to all of the items.
- Crawl content as anonymous: If this option is set, then no access token is required. However, only public content is crawled.
- Process body.storage as document: If enabled, the connector uses the storage representation of the page at indexing time instead of the exported view. You gain performance (especially if external content is included via plug-ins), but the page content may not match what users see via browsers.
- Time zone: Set the time zone to the same zone that is configured in the Confluence Server.
Note: The host must be added to the postgresql.conf file and the PostgreSQL service must be restarted for the changes to take effect.
Connection Settings for the SQL or PostgreSQL Server Modes
- Password: If integrated security is used in the connection Connection defines the how Connectivity Hub connects to your Source System (which contains your documents, graphics, etc.,).
Your Connection includes identifying elements such as: URL of the BA Insight web service connector you are using, (File Share connector, SharePoint Online connector, etc.), Authentication mode, User Accounts and Credentials, Database information (for database connectors) string, type only the certificate password only. (As specified using the Generate the Authorization Token section.) Otherwise, type the certificate and SQL connection passwords separated by a pipe (
|) character. - Confluence URL: This is the URL that can be used in Web browsers to reach the Confluence UI.
- Return labels as metadata: If this option is enabled, the labels are returned in a custom metadata property. Use this setting only if required due to performance impact. This impact is because an extra API call is required.
- Return all items as public: This setting skips the permission checks for the crawled items in the search index. For this reason, all users have access to all of the items.
- Database Server Connection string: Specify here the standard ADO.Net connection string to access the database. Do not specify the password directly in the connection string; instead use the Password field described above.
- Process body.storage as document: If enabled, the connector will use the storage representation of the page at indexing time instead of the exported view. You gain performance (especially if external content is included via plug-ins) but the page content may not match what users see via web browsers.
- Time zone: Set the same time zone to the same zone that is configured in the Confluence server.
Connection settings for OAuth modes
Client Id: Specify the client Id that is attached to the application link. For more information, see Generate the authorization token.
Content configuration specifics
Using Custom filters
The Confluence connector uses a JSON string to include or exclude spaces and pages in crawls. For more information on how you can configure custom filters, see Filter content from a Content Source in the Connectivity Hub documentation. The Confluence connector supports two types of custom filtering:
- filter crawls for specific spaces: Type space keys with quotation marks (“”) separated by commas (,):
"Spacekey1", "Spacekey2", "Spacekey3".
- filter crawls for specific pages: Type page titles in double quotes (“”):
“My First Page”, “My Second Page”.
Refer to the following code sample to see how you can structure your custom filter JSON:
"filter": {
"include": {
"spaces": ["SPACETOINCLUDE1", "SPACETOINCLUDE2"],
"pages": ["GlobalPageToInclude1", “GlobalPageToInclude2”],
"scopedPages ": [
{ "space": "SPACE3", "Page": "Page1TogetFromSpace3" },
{ "space": "SPACE3", "Page": "Page2TogetFromSpace3" }
"exclude": {
"spaces": ["SPACETOEXCLUDE1", "SPACETOEXCLUDE2"],
"pages": ["GlobalPageToExclude1", "GlobalPageToExclude2"],
"scopedPage": [
{ "space": "SPACE5", "page": "PageToExcludeFromSpace5" }
Configure SharePoint for the Confluence Connector
Confluence generates URLs that are incompatible with SharePoint crawling operations.
For this reason, BA Insight recommends setting the item URL in the Connector Framework Content > Content Definition tab > Item URL to use the DocLoader facility that is provided by the Connector Framework.
If you want to expose the original Confluence URLs to your search users, follow these steps:
- Create an additional managed property, using the Connector Framework to capture the
SPW_URLvalue, which contains the Confluence URL. - Update the display templates in the search results to show the Confluence URL to your users.
For information about how to configure the DocLoader URL, see Connector Framework help on the Upland Right Answers Portal.
Confluence Cloud Connector
Specify your settings based on the mode that you chose in the Confluence Connectors Prerequisites section.
Content Configuration Specifics
"filter": {
"include": {
"scopedPages ": [
"exclude": {
"scopedPage": [
How to Configure SharePoint for the Confluence Cloud Connector
