How to Register the Nuxeo Connector as an External App
Use the following steps to register the BA Insight Nuxeo connector in Nuxeo as an external application. Before you begin, ensure that you have Installed and configured the BA Insight Nuxeo Connector.
Prepare for Basic Authentication
Basic authentication doesn't require any steps before configuration.
Prepare for oAuth-Based Authentication
Use the following instructions to prepare your connector for oAuth Specifies a process for resource owners to authorize third-party access to their server resources without providing credentials.-based authentication.
  1. Start IIS Management Console. Under Sites, select BA Insight Nuxeo Connector.
  2. Click the Content View tab on the bottom, right-click OAuth.html and select Browse from the sub-menu that appears.
  3. The BA Insight Nuxeo Connector web page appears.
  4. In the appropriate fields, specify the Nuxeo URL and Nuxeo Administrator account, and then click the Authorize button.
  5. A green message indicates that authorization was successful.
