ServiceNow connector release notes
The respective releases of the ServiceNow connector feature the following enhancements. For more information about the connector, see About the SeviceNow connector.
ServiceNow v2.6.1.0
System enhancements
There are no system enhancements in this release.
Fixed issues
In the previous release of ServiceNow, support was added for crawling additional ServiceNow tables, causing issues in environments with strict regulatory requirements. The ServiceNow connector will now ignore crawling datastores when a table is missing (for example, when a feature, such as ServiceNow News, is not installed), or when a permission has not been granted to the necessary tables to crawl. (1846298)
ServiceNow v2.6.0.0
System enhancements
| Item | Description |
| Support for crawling news, topics, and web application content |
This release of the ServiceNow connector adds the ability to crawl ServiceNow news, topics, and web application content. To enable this functionality, you must install the appropriate plugin and grant access to the applicable table in ServiceNow. For more information, see Additional steps for crawling news, topics, or web applications in the setup documentation. |
| Configuration enhancements |
This release of the ServiceNow connector adds the following configuration settings:
For more information, see Set up and configure the ServiceNow Connector. |
| metadata enhancements |
Knowledge blocks will now have enhanced metadata properties:
Knowledge articles now have new metadata properties:
Fixed issues
An error was returned if an empty response was returned for ValidateUser. (1748117)
The connector was not checking for user criteria that was placed on the catalog, which resulted in some items being incorrectly marked as public. (1782984)
ServiceNow v2.5.1.0
System enhancements
| Web.config enhancements |
This release of the ServiceNow connector adds the following settings to the web.config file:
Fixed issues
If the ServiceNow connector was configured with OAuth Specifies a process for resource owners to authorize third-party access to their server resources without providing credentials. authentication, you were not able to specify a short username for your ServiceNow instance. (BAI-17560)
The ServiceNow connector was processing inactive users in the user criteria evaluation. (BAI-17284)
The ServiceNow connector could only process user criteria in parallel, which caused timeouts in large environments. (BAI-17259)
ServiceNow v2.5.0.0
System enhancements
| Support for OAuth authentication |
This release of the ServiceNow connector adds support for OAuth authentication. For more information on setting up and configuring OAuth, see Set Up and Configure the ServiceNow Connector. |
| Support for custom filters | You can now choose to include or exclude category items, such as Catalogs, Knowledge Bases, or Incidents from your index. For more information, see Set Up and Configure the ServiceNow Connector. |
Fixed issues
The ServiceNow connector was not excluding items from the crawl that were specified to be excluded in the Connectivity Hub category filter. (BAI-16432)
ServiceNow v2.4.2.0
System enhancements
Fixed issues
The following issues have been fixed in this release:
If the admin was not given permissions to specific Service Portal roles, such as announcements, the ServiceNow connector would fail when a datastore load job Collects the logical division of your data (data stores) from the source system. Runs on a schedule Logs information according to log level set was run, even if the feature that requires the role was not being used. The connector now only requires permissions for the objects that are crawled. (BAI-15290)
During a crawl job, some metadata properties were unable to be returned by the ServiceNow connector. (BAI-15325)
During a crawl job, the ServiceNow connector was not returning attachments. (BAI-15409)
Admin privileges were extending to users who shared other roles in common with the administrator. (BAI-16149)
ServiceNow v2.4.0.0
System enhancements
Search Results are displayed in SmartHub with Advanced security rules applied
Fixed issues
Connector fails to crawl item with "Error During DoItemData: Input string was not in a correct format." (BAI-14100)
Incremental crawls Scanning and capturing only new data from all of your content sources. This data did not exist when the last crawl was run. were not updating items. (BAI-11326)
The multilevelsecured property was misspelled. (BAI-3867)
