Set up and configure the ndMirror connector
All BA Insight connectors can be downloaded from the Upland Right Answers Portal under Knowledge > BA Insight > Product Downloads > Connectors. This connector is installed with the same generic steps as any BA Insight connector. You must satisfy the Prerequisites for your connector before installing. The configuration specifics are detailed below.
Connection Configuration
After downloading and installing the ndMirror connector, use the following instructions to add the connection Connection defines the how Connectivity Hub connects to your Source System (which contains your documents, graphics, etc.,). Your Connection includes identifying elements such as: URL of the BA Insight web service connector you are using, (File Share connector, SharePoint Online connector, etc.), Authentication mode, User Accounts and Credentials, Database information (for database connectors) in Connectivity Hub:
Navigate to the Connectivity Hub administration portal.
In the left panel, click Connections > New Connection > Web Service Connection.
Enter the Web service URL and specify the Authentication mode for your connector.
Click Connect. If successful, the Edit Web Service Connection page displays.
On the Connection Info tab, provide a title for your connection.
Click the General Settings tab and provide the following:
In the Max concurrent requests field, specify the number of requests that the connector can make in parallel.
In the Connection String field, enter the connection string to your ndMirror SQL server instance. For example,
Server=myServerAddress; Database=myDataBase; User Id=myUsername; Password=myPassword; -
In the Repository Id field, enter the repository Id for your ndMirror instance. For example, CA-98MFCFAZ. If the authorized user is connected to multiple repositories, you can use this filter to specify only the repositories you want the user to crawl.
Check the Include External checkbox to include external users and groups from the security sync Loads User and Group tables and executes the mapping based on the connector configuration. task.
Check the Disable Security checkbox to ignore security and make all of your content public.
In the Data Center Url field, enter the Data Center Url for your NetDocuments instance. Refer to the NetDocuments documentation for more information.
Click Save Changes.
