SharePoint Online connector release notes
The SharePoint Online connector can be downloaded from the Upland Right Answers portal. The following lists the enhancements and fixed issues that were implemented in a specific version of the SharePoint Connector.
SharePoint Online Connector 2.1.4.2
System Enhancements
Feature Description
SharePoint Online connector configuration
You can now configure the following setting when configuring your SharePoint Online connector:
Fixed issues
  • In some scenarios, when using the certificate-based authentication model with the Sites.Selected permission, the connector logs showed a throttling error. (1855824)
SharePoint Online Connector 2.1.4.1
System Enhancements
There are no system enhancements in this release.
Fixed issues
SharePoint Online Connector 2.1.4.0
System Enhancements
Feature Description
Support Certificate-Based Authentication Without Local Admin Rights
When configuring the SharePoint Online connector using App Registration with Certificate Authentication, users previously needed Local Administrator rights to install the certificate into the Local Machine Trusted Root store (LocalMachine\Root). The connector has been enhanced to allow use of certificates installed in the Current User Personal Store (CurrentUser\My), removing the Local Administrator requirement.
For more information, see Certificate-based authentication for SharePoint Online Connectors.
Azure Active Directory An identity and access management solution from Microsoft that helps organizations secure and manage identities for hybrid and multicloud environments. user synchronization enhancements The SharePoint Online connector will now only synchronize specified users from Azure Active Directory A directory service for Windows domain networks. A hierarchical structure that stores information about objects on the network. Used to manage permissions and control access to critical network resources. that are included in groups from the SharePoint site as configured in the connection Connection defines the how Connectivity Hub connects to your Source System (which contains your documents, graphics, etc.,). Your Connection includes identifying elements such as: URL of the BA Insight web service connector you are using, (File Share connector, SharePoint Online connector, etc.), Authentication mode, User Accounts and Credentials, Database information (for database connectors). Previously, The SharePoint connector would load all users from Azure Active Directory regardless of their usage.
Fixed issues
SharePoint Online Connector 2.1.3.0
System Enhancements
Fixed issues
  • In some scenarios, security sync tasks were failing after a new datastore was added. (BAI-18076)
  • The SITEURL filter was not crawling specified sub-sites. (BAI-17905)
  • When running a datastore load task with the SharePoint Online connector, the task was successfully completed, but no results were returned. (BAI-17737)
SharePoint Online Connector 2.1.2.0
System Enhancements
Fixed issues
  • The SharePoint Online connector was not permitting username/password authentication when calling /sites/getAllSites. (BAI-17738)
  • The SharePoint Online connector caps the parallel processing value to one below the maximum number of processing cores. When the value of the MaxDegreesOfParallelism setting in the web.config file was set to a number higher than the maximum number of processing cores, the connector was not automatically adjusting the value. (BAI-17701)
SharePoint Online Connector 2.1.1.0
System Enhancements
The following enhancements are new in this release of the SharePoint Online connector:
Enhancement Description
Web.config enhancements
The following web.config settings are new in this release:
  • You can now override your tenant name by specifying a vanity link for your SharePoint Online connector configuration with the "TenantName" setting.
  • You can now enable or disable memory caching for security syncs for unified members, role members, and SharePoint members with the following settings:
    • "EnableSecurityUnifiedMembersCaching"
    • "EnableSecurityRoleMembersCaching"
    • "EnableSecuritySharePointMembersCaching"
  • You can now control the amount of memory caching that you want to allow for your connector with the MemoryCacheThreshold" setting.
For more information, see configure the SharePoint Online connector using web.config.
Security Sync improvements Security Sync tasks have been enhanced to improve performance and efficiency.
Fixed issues
  • Crawling the AkuminaCentral datastore with a SharePoint Online connector produced an error. (BAI-16831)
  • When performing a full crawl with a custom filter applied to specify a folder URL, the documents were not appearing in the crawl results. (BAI-16935)
  • Authentication was failing when using vanity URLs for the tenant. (BAI-17258)
  • If a SharePoint Online site was included in a security sync and then deleted in SharePoint Online, the subsequent security sync job would fail. (BAI-17260)
  • The SharePoint Online connector was not correctly processing the Everyone except external users group when it was included as a child group. (BAI-17436)
SharePoint Online Connector 2.1.0.0
System Enhancements
Certificate-based authentication for specified site collections You can now grant the Sites.Selected permissions to restrict access only to the site collections you want to be indexed. For more information, see certificate-based authentication.
Document Library enumeration The SharePoint Online connector now uses Microsoft Graph API to enumerate document libraries. This improves the performance of incremental crawls, as only document libraries that require recrawls will be crawled.
Fixed issues
  • When a parent folder was deleted, items in child folders were not being reported as deleted in Connectivity Hub. (BAI-14516)
  • When an incremental crawl was performed using the SharePoint Online connector, the connector was not logging and identifying document libraries that required a full recrawl. (BAI-15827)
  • The SharePoint online connector did not support tenants with ".us" domains. For example, login.microsoftonline.us. (BAI-16521)
SharePoint Online Connector 2.0.9.0
System Enhancements
Fixed issues
SharePoint Online Connector 2.0.7.0
System Enhancements
Fixed issues
  • SharePoint Online connector crawls run from Connectivity Hub fail: Failed to resolve groups: NOTFOUND. (BAI-14313)
  • Connector content filter options do not work. (BAI-14385)
  • [Advisory] Security Sync missing Everyone except External users. (BAI-14422)
SharePoint Online Connector 2.0.5.0
System enhancements
  • Documentation updated to reflect latest changes.
  • Code optimization and caching enhancements.
  • Multiple functional enhancements to handle different found cases as show in the issues list.
Fixed Issues
