Sitecore Connector Prerequisites
| Required Permission | Description |
| Sitecore Account |
Item Web API configuration
The Sitecore connector uses the Item Web API to communicate with SiteCore. However, it can connect only if remote connections and standard security are enabled:
<configuration xmlns:patch="http://www.sitecore.net/xmlconfig/">
<sitecore>
<settings>
<!-- Set itemwebapi policy to allow remote connections, otherwise requests will fail -->
<setting name="Sitecore.Services.SecurityPolicy"
value="Sitecore.Services.Infrastructure.Web.Http.Security.ServicesOnPolicy, Sitecore.Services.Infrastructure" />
</settings>
<sites>
<site name="website">
<!-- Patch website to allow itemwebapi with StandardSecurity -->
<patch:attribute name="itemwebapi.mode">StandardSecurity</patch:attribute>
</site>
</sites>
</sitecore>
</configuration>
| Sitecore Support |
recent versions supported |
Sitecore version 10 requires a file be copied from your Sitecore server. See Before You Start. |
| Searchable content types | Yes | All content types. |
| Content Update | Full and Incremental | All BA Insight Connectors support both Full and Incremental crawls, unless noted. |
| Permission Types | Yes |
| Required Software | .NET Framework v4.7.2 |
