Veeva Vault connector release notes
The respective releases of the Veeva Vault connector feature the following enhancements. For more information about the connector, see About the Veeva Vault connector
Veeva Vault connector 1.0.19.0
System Enhancements
There are no system enhancements in this release.
Fixed issues
When running a datastore types load job Collects the types of data from your source system. Runs on a set schedule. Requires a log level which logs information with the Veeva Vault connector, documents with exceedingly long document or property names would cause the job to fail. (1845341)
Veeva Vault connector 1.0.18.0
System Enhancements
Fixed issues
When crawling a large number of documents, if the API limit specified in the web.config file was reached, the connector would sleep for an hour leading to "invalid Session ID" errors. (BAI-16300)
If the Veeva Vault connector content source Content Sources do the following: Receive data from the Source System via the Connection, Filter the data it receives, Provide the results to the Target, Define the specific search index that contains the content you wish to index (and later search). was configured with a complex query filter with nested "AND" and "OR" operators, items would incorrectly be included or excluded from the crawl. (BAI-16316)
If an incremental crawl Scanning and capturing only new data from all of your content sources. This data did not exist when the last crawl was run. was run right after a full crawl, it would fail due to an invalid DateTime error. (BAI-16777)
Veeva Vault connector 1.0.17.0
System Enhancements
| Feature | Description |
| Support for auto-managed groups | The Veeva Vault connector now supports fetching auto-managed groups. Auto-Managed groups are automatically created and populated by Veeva Vault during user role setup. For more information, see the Veeva Vault documentation. |
Fixed issues
Search queries that used "OR" or "AND" conditions were not being parsed correctly, resulting in no results being returned and an error is displayed in the crawl log. (BAI-15547)
The Veeva Vault connector was only crawling documents that were included on the first page of results. (BAI-15218)
