Website Connector Prerequisites
| Searchable content types | Yes |
| Content Update | Full and Incremental |
| Permission Types | No |
| Required Software | .NET Framework v4.7.2 |
| Hardware |
Rending HTML web pages requires a large amount of CPU resources and memory. BA Insight recommends the following hardware:
Authentication Protocols
The following Authentication protocols are supported
| Authentication Protocol | Description | Prerequisite |
| Anonymous Access |
The connector does not pass any information to the web server. |
None |
| HTTP Basic Authentication |
The connector passes the username and password for authentication via the standard HTTP Headers. |
The username/password for the account to use for authentication. |
| Azure AD An identity and access management solution from Microsoft that helps organizations secure and manage identities for hybrid and multicloud environments. Application |
The connector interacts with Azure Active Directory An identity and access management solution from Microsoft that helps organizations secure and manage identities for hybrid and multicloud environments. to obtain a token and pass it as the HTTP Authorization header |
The website must be secured via Azure AD A directory service for Windows domain networks. A hierarchical structure that stores information about objects on the network. Used to manage permissions and control access to critical network resources. The connector requires the following:
| oAuth Specifies a process for resource owners to authorize third-party access to their server resources without providing credentials. Authentication |
The Application used by the website must be configured as follows:
The website must be modified to add an extra page to initialize the application for the purpose of crawling. When the website is crawled, this page is called with the ID or Access tokens passed via the URL. The page is then responsible for storing the necessary token in the right location so that the crawling account is considered as successfully authenticated and the browser will not prompt for authentication Additionally, make sure you have the following information before starting the installation and configuration:
