iManage Connector Prerequisites
User accounts and application permissions
Required Permission |
Description |
| iManage User Account | The account used to crawl your items must have full READ permissions to all the content to be indexed from the iManage. |
| iManage System Account | This account is required if you are using the iManage Sync API. You must obtain a system account from iManage to be able to configure a connector with the Sync API service. |
Connector features and requirements
For security information, see iManage Connector Security.
Features |
Supported |
Additional Information |
| iManage version | +v10 | One installation per iManage tenancy |
| Searchable content types | Yes | The iManage connector enables you to connect to iManage source system Your Source System is the repository where your data is stored (data to be indexed). This repository is managed by applications such as: - SharePoint O365 - SharePoint 2013/16/19 - Documentum - File Share - OpenText - Lotus Notes - etc. Your Source System repository can also be a database such as SQL or Oracle., fetch data from any workspace and index this content securely. |
| Content Update | Full and Incremental | All BA Insight Connectors support both Full and Incremental crawls, unless noted. |
| Permission Types | Yes |
| Required Software | .NET Framework v4.7.2 | One installation per iManage tenancy. |
Upgrading from an earlier version of the connector
When upgrading to BA Insight iManage Connector v2.0.0.0-19672 (or later) from an earlier version, you must run an index reset and full crawl.
If you are upgrading to the iManage connector 2.1.0.0, and you are going to use the new iManage with Sync API service, you must rerun all your security sync jobs Loads User and Group tables and executes the mapping based on the connector configuration. and perform a full crawl job. For more information, see run required jobs in the Connectivity Hub documentation.
Register a new application with iManage
To allow the connector to connect to your iManage source system, an iManage registered app is required:
If you are using iManage cloud, this step is optional as the Upland BA Insight iManage connector provides a preregistered iManage application. However, if you would like to register your own application with iManage, you can do so with the instructions below.
If you are using iManage On-prem, you must follow the instructions below and have an admin user account with access to the iManage Control Center to register and enable a new application with iManage.
To register your application(s), open a ticket by sending an email request to appregistration@imanage.com with the following information:
- Application Name
- Provide an appropriate name for your application
- Application Type
- Web App
- OAuth2 Redirect_Url
- http://localhost:2292/oauthresult.aspx
Once your application(s) have been registered, you will receive an email for your ticket indicating that the request has been fulfilled.
Perform the following steps at this point:
- Go to your folder in iManage Share.
- Find the document "Technology Partner Cloud iManage Credentials".
- Refer to the section which defines the OAuth2 information that your application(s) have been registered with.
- This includes key information such as:
- client_id
- client_secret
- redirect_url
- After you have received notification that your application(s) are registered, enable them in the iManage Control Center (https://cloudimanage.com/imcc) in your developer sandbox.
