How to Use the SmartHub Basket
About SmartHub Basket
The SmartHub basket module enables you to collect results from different pages across SmartHub.
See the My basket icon in the top-right of the following screenshot:
My basket example
How to Configure the SmartHub Basket
To configure the Basket component, edit the Custom Settings file that you are using for your SmartHub pages.
For more information about using Custom Settings, see How to Use the UI Builder.
  • You can change the Basket options by adding and editing the Basket code in your custom settings file.
  • You can override any setting by adding it to the SH.Basket.CustomSettings namespace.
UI Builder
The easiest and fastest way to work with the Ribbon component is via the SmartHub UI Builder.
For information about how to access the UI Builder as well as who can access it, see How to Use the UI Builder.
  1. SmartHub administrators can simply click the UI Editor link from the SmartHub ADMINISTRATION page.
  2. Click the Advanced link at the top right of the window to enter Advanced mode.
  3. Select (double-click) the page (Index.html, landing.html, etc.) you wish to modify.
    1. Below, the Results.html page is shown for sample purposes.
    2. BA Insight recommends you create your own custom page (within its own folder) to modify. Leave the default files as templates.
  4. Select the Advanced settings edit link at the top center of the page.
  5. Scroll down to around line 298 on the page.
  6. To access the available Basket settings, click the See Default Settings link in the top right corner.
    1. A new browser tab opens with all available SmartHub module settings.
    2. Search for the word "Basket" on the page to quickly navigate to the Basket default settings, shown below:
    Copy
        SH.Basket = SH.Basket || {};
        SH.Basket.DefaultSettings = {
            ".basketButton": {
                Enabled: false,
                RequiresTracking: true,
                GroupName: "global",
                IDMetadata: 'clickUri',
                BasketModalID: "basketModal",
                Labels: {
                    AddItem: "Add to basket".toLocaleString(),
                    RemoveItem: "Remove from basket".toLocaleString(),
                    BasketTitle: "My Items".toLocaleString(),
                    BasketButton: "Automation basket".toLocaleString(),
                    CancelButton: "Cancel".toLocaleString(),
                    CheckoutOptions: "Checkout options".toLocaleString()
                BasketTemplatePath: SH.RootLevelURL + "/modules/Basket/templates/basketTemplate.html",
                ItemTemplatePath: SH.RootLevelURL + "/modules/Basket/templates/itemTemplate.html",
                ButtonTemplatePath: SH.RootLevelURL + "/modules/Basket/templates/buttonTemplate.html",
                BasketClass: "sh-basket",
                BasketIconClass: "sh-icon-button fas fa-cart-plus",
                RemoveIconClass: "sh-icon-button remove-btn fas fa-cart-arrow-down",
                WarningMessage: "ID Metadata configured is empty or doesn't exist! 'Add to basket' button will not be displayed.".toLocaleString(),
                BasketLimitInfoMessage: "You have reached the maximum number of items allowed in basket.".toLocaleString(),
                BasketLimit: 100
  7. Copy the desired settings from here into the open HTML file in the Advanced settings editor in your previous browser tab.
  8. Click Save changes at the bottom of the screen.
Basket Configuration Example
Copy
 SH.Basket.CustomSettings =
            ".basketButton": {
            Enabled: true,
            Labels: {
            BasketLimit: 50
Parameters
The individual basket settings are:
Option
Value
Comment
Enabled
Boolean
Default: false
If this is set to "false" the component doesn't make any changes to SmartHub and doesn't load any dependency
GroupName
Text
Default: "global"
Puts the item in the specified group.
IDMetadata
text
Default: "clickUri"
The metadata used to create the item id
BasketModalID
text
Default: "basketModal"
The Id used for the basket modal
SearchInterfaceElement
Text
Default: ".CoveoSearchInterface"
The SearchInterface element that the basket attaches to
Labels
Object
Labels: {
            AddItem: "Add to basket",
            RemoveItem: "Remove from basket",
            BasketTitle: "My Items",
            BasketButton: "My basket",
            CancelButton: "Cancel",
The list of labels seen in the module UI.
BasketTemplatePath
Text
Default: SH.RootLevelURL + "/modules/Basket/templates/basketTemplate.html"
The template for the basket modal window
ItemTemplatePath
Text
Default: SH.RootLevelURL + "/modules/Basket/templates/itemTemplate.html"
The template for each item rendered inside the basket modal window
ButtonTemplatePath
Text
Default: SH.RootLevelURL + "/modules/Basket/templates/ibuttonTemplate.html"
The template for "My Basket" button
BasketClass
Text
Default: "sh-basket"
The class for the “My basket” button
BasketIconClass
Text
The class for the “My basket” button icon and the "Add to basket" button icon
RemoveIconClass
Text
The class for the "Remove from basket" button icon
WarningMessage
Text
Default: "ID Metadata configured is empty or doesn't exist! 'Add to basket' button will not be displayed."
The message displayed in console in case that 1 items doesn't contains the metadata configured
Text
Default: "You have reached the maximum number of items allowed in basket."
The message is displayed in an Alert in case that the limit of items that can be added in basket is reached
BasketLimit
Integer
Default: 100
The limit that items can be added in basket
Exposed Functions and Available Events
Available Events
Event name Trigger Data
basketCreated
Triggered when the basket modal window is created
{ BasketKey: basketKey }
mainBasketButtonCreated
Triggered when the "My Basket" button is created
{ BasketKey: BasketParentSelector}
basketExpanded
Triggered when the basket modal window is opened
basketCollapsed
Triggered when the basket modal window is closed
itemAddedToBasket
Triggered when an item was added to the basket
{ BasketKey: BasketParentSelector, id: item id, itemMetada: Search Query Result}
itemRemovedFromBasket
Triggered when an item was removed from the basket
{ BasketKey: BasketParentSelector, id: item id }
Exposed Functions
Function name Function Call Description
SH.Basket.Expand
SH.Basket.Expand("BasketKey")
This function can be called to programmatically show the basket modal
Example:
Copy
SH.Basket.Expand(".basketButton");
SH.Basket.Collapse
SH.Basket.Collapse("BasketKey")
This function can be called to programmatically hide the basket modal
Example:
Copy
SH.Basket.Collapse();
SH.Basket.AddItem
SH.Basket.AddItem("BasketKey", "itemId", itemMetdataJson)
This function can be called to programmatically add an item to the basket.
Item metadata JSON example for the minimum metadata required for the out-of-the-boxbasket item template
Copy
    itemId:"itemId",
    title:"title",
    ContentSource:"ContentSource",
    clickUri:"clickUri"
Example:
Copy
var exampleItemMetadata = { itemId:"exampleItemID", title:"Example item", ContentSource:"", clickUri:"" }
SH.Basket.AddItem(".basketButton", "exampleItemID", exampleItemMetadata);
SH.Basket.RemoveItem
SH.Basket.RemoveItem("BasketKey", "itemId")
This function can be called to programmatically remove an item from the basket
Example:
Copy
SH.Basket.RemoveItem(".basketButton", "exampleID");
SH.Basket.RemoveAllItems SH.Basket.RemoveAllItems("BasketKey")
This function can be called to remove all items from the basket
Example:
Copy
SH.Basket.RemoveAllItems(".basketButton");
SH.Basket.GetAllItems
SH.Basket.GetAllItems("BasketKey")
This function can be called in order to programmatically obtain all the items from the basket.
This function returns a promise.
Example on how to use it:
Copy
SH.Basket.GetAllItems(".basketButton").then(function(basketItems){
    Object.keys(basketItems).forEach(function (key) {
        SH.Basket.RemoveItem(".basketButton", key);
SH.Basket.AddCheckoutOption
SH.Basket.AddCheckoutOption("BasketKey", "Checkout Name", function )
This function is used to inject checkout options.
Example:
Copy
var ClearBasket = function(){SH.Basket.GetAllItems(".basketButton").then(function(basketItems){Object.keys(basketItems).forEach(function (key) {SH.Basket.RemoveItem(".basketButton", key);}); })};
SH.Basket.AddCheckoutOption(".basketButton", "Example1", function(){SH.Basket.GetAllItems(".basketButton").then(function(basketItems){Object.keys(basketItems).forEach(function (key) {SH.Basket.RemoveItem(".basketButton", key);}); })});
SH.Basket.AddCheckoutOption(".basketButton", "Example2", ClearBasket );
How to Add a Checkout Option
Copy
var ClearBasket = function(){SH.Basket.RemoveAllItems(".basketButton");};
$(document).on('basketCreated',function(){
  SH.Basket.AddCheckoutOption(".basketButton", "Example1", function(){SH.Basket.RemoveAllItems(".basketButton")});
  SH.Basket.AddCheckoutOption(".basketButton", "Example2", ClearBasket);
How to Add Multiple Baskets
Copy
 SH.Basket.CustomSettings = {
        ".basketButton":{
            Enabled: true,
            SearchInterfaceElement: ".CoveoSearchInterface",
            BasketModalID:"basketModal",
            Labels: {
                BasketButton: "My basket".toLocaleString(),
            BasketClass:"sh-basket",
        ".favorites":{
            Enabled: true,
            GroupName: "favorites",
            Labels: {
                AddItem: "Add to favorites".toLocaleString(),
                RemoveItem: "Remove from favorites".toLocaleString(),
                BasketButton: "My favorites".toLocaleString(),
            RemoveIconClass: "sh-icon-button remove-btn fas fa-cart-arrow-down"        }
