How to Configure the DatePicker Refiner
About the Date Picker Refiner
  • Refiners, which are stored in the file Results.html at the SmartHub root level, can be added, removed, or modified.
  • Before using refiners or making changes to any SmartHub files, see How to Add Refiners to Your Search Results.
  • SmartHub, by default, provides the out-of-the-box Date Picker refiner.
  • This refiner helps users select the date interval for their query results.
The date picker code in the SmartHub file Results.html is shown here:
How to Modify the Date Picker Refiner
  • The default interval for the date picker refiner is auto.
  • The interval for the date picker is changed based on current query.
  • Users can modify this by specifying the options:
    • data-start
    • data-end
  • In case you want data-end to be the current date, remove data-end from the configuration and current date will be displayed.
    This code produces something like the following:
  • Users can also specify the default state, which out-of-the-box, comes as collapsed.
    This produces:
  • This refiner uses the JavaScript component daterangepicker that has several configuration options available.
  • Users can specify this options by modifying the data-raw-options option.
  • Use this feature with care, since it is prone to errors.
    The data-raw-options value must have a JSON format.
