How To Configure the SearchBox
About SmartHub SearchBox
The SmartHub SearchBox module enables you to execute queries.
How to Configure the SmartHub SearchBox
UI Builder
The easiest and fastest way to insert and customize the SearchBox is via the SmartHub UI Builder.
To configure the SearchBox component, you edit the Advanced Settings file that you are using for your SmartHub pages (procedure below).
For more information about using Custom Settings, see How to Use the UI Builder.
 - You can override any setting by adding it to the
SH.SearchBox.CustomSettingsnamespace.
Procedure:
SmartHub administrators can simply click the UI Editor link from the SmartHub ADMINISTRATION page.
Select (double-click) an HTML page such as Results.html page.
BA Insight recommends you use page and folder to modify. Leave the default files as templates.
Example: pages/CustomResults.html. Default Results.html is under the top most SmartHub directory.
Select the Advanced mode from the top right of the page.
Select Advanced settings edit.
Scroll down to line 301 (this may vary), which contains the text "
SH.SearchBox.CustomSettings"
Click the See Default Settings link at the top right.
Scroll down (towards the bottom of the page) to the line that contains the text "
SH.SearchBox.DefaultSettings = {"
Copy the settings under settings after the text "SH.SearchBox.DefaultSettings = {".
Go back to your Advanced settings edit tab.
Paste the copied settings inside the section "SH.SearchBox.CustomSettings = {".
Modify the settings as desired. See the table SearchBox Settings below for more information.
Note the Template files referenced:
searchboxTemplate.html
scopedSearchTemplate.html
keepRefinersTemplate.html
These templates can be modified. They are located in the directory:
<SmartHub-install-dir>\modules\SearchBox\templates
Click the link "Preview <file>.html" at the top of the page.
Return to the previous page and make changes, if necessary. Repeat Step 15 until the desired results are achieved.
Click Save changes.
Example Configuration
SH.SearchBox = SH.SearchBox || {};
    ".sh-search-section": {
        Enabled: true,
        SearchBoxTemplatePath: SH.RootLevelURL + "/modules/SearchBox/templates/searchboxTemplate.html",
        ScopedSearchTemplatePath: SH.RootLevelURL + "/modules/SearchBox/templates/scopedSearchTemplate.html",
        KeepRefinersTemplatePath: SH.RootLevelURL + "/modules/SearchBox/templates/keepRefinersTemplate.html",
        ShowScopedSearch: true,
        ShowKeepRefiners: true,
        RemoveResultsOnClear: true,
        ShowSelectedScope: false,
        EnableDuplicateSearch: true,
        ModuleDetails: {
            SearchBoxPlaceholder: "Search...".toLocaleString(),
            KeepRefinersLabel: "Keep Refiners".toLocaleString()
    ".search-within": {
        Enabled: false,
        SearchWithin: true,
        ModuleDetails: {
            SearchBoxPlaceholder: "Search within...".toLocaleString(),
                                                    Note: Make sure that an element with the identifier specified in the SearchBoxParentSelector setting exists on your page;
The SearchBoxParentSelector is also the key used to identify the SearchBox.
The out-of-the-box value for the SmartHub SearchBox is ".sh-search-section".
        ".sh-search-section":{
            Enabled: true,
            ShowScopedSearch:true,
            ShowKeepRefiners:true,
            RemoveResultsOnClear:true,
            ShowSelectedScope:false,
            EnableDuplicateSearch:true,
            ModuleDetails: {
                                                    SearchBox Settings
The SearchBox parameters and their values are listed below.
                                                             Setting  |
                                                             Value  |
                                                             Description  |
| Enabled |
                                                             Boolean Default: false  |
                                                        If this is set to "false", the component does not make any changes to SmartHub and does not load any dependency. |
                                                             SearchBoxTemplatePath  |
                                                             string Default: SH.RootLevelURL + "/modules/SearchBox/templates/searchboxTemplate.html"  |
                                                        The path to the template used for the SearchBox |
                                                             ScopedSearchTemplatePath  |
                                                             string Default: SH.RootLevelURL + "/modules/SearchBox/templates/scopedSearchTemplate.html"  |
                                                        The path to the template used for the ScopedSearch verticals |
                                                             KeepRefinersTemplatePath  |
                                                             string Default: SH.RootLevelURL + "/modules/SearchBox/templates/keepRefinersTemplate.html"  |
                                                        The path to the template used for the KeepRefiners toggle |
                                                             ShowScopedSearch  |
                                                             Boolean Default: true  |
                                                        Enables you to show/hide the ScopedSearch selector |
                                                             ShowKeepRefiners  |
                                                             Enables you to show/hide the KeepRefiners toggle. If there are no refiners on the page, the KeepRefiners toggle will be automatically disabled.  |
                                                             RemoveResultsOnClear  |
                                                        Enables you to clear the results when you remove the text from the SearchBox |
                                                             ShowSelectedScope  |
                                                        Enables you to show/ hide the name of the selected scope |
                                                             EnableDuplicateSearch  |
                                                        Enables you to execute multiple queries for the same query text |
                                                             ModuleDetails  |
                                                             Object Default: {  |
                                                             Contains the labels used in the SearchBox component  |
The SearchBox has a special container that should be used as a container when showing different components that need to be next to the SearchBox.
That container has the class ".searchbox-widgets" and it should be targeted via the SearchBoxParentSelector.
Example:
".sh-search-section .searchbox-widgets"
Example showing the personalization link:
Exposed Functions and Available Events
Available Events
| Event name | Trigger | Data |
                                                             SearchboxAdded  |
                                                        Triggered when the SearchBox is created |
                                                             {SearchBoxKey: key}  |
