Document Loader Service
Note: Before proceeding, ensure the SmartHub to Connectivity Hub connection is configured.
See Connectivity Hub Settings Configuration.
About
The DocumentLoader service is located at the following URL:
https://<smarthub-web-app>/_bai/v1/document
Replace <smarthub-web-app> with the address of your own SmartHub instance.
There is one endpoint to call:
https://<smarthub-web-app>/_bai/v1/document/load
Load
The method provides the functionality needed to access documents without having to reach the source system and instead download them directly from the search page.
- Only items indexed through Connectivity Hub or Connector Framework can be used with this service.
- To enable the functionality you first have to configure the content so that the URLs indexed point to this service.
- Follow instructions here (under Content Configuration).
- The article describes how to do this for a FileShare Connector, but the approach is the same for any other connector.
- You also need to configure your SmartHub instance to communicate with Connectivity Hub.
- Follow the instructions here.
Request details:
- Method: GET
- Parameters:
- source
- Query string, Mandatory
- Parameter that contains the encoded
escbase_crawlurlproperty of the document you want to download.
- This property ONLY exists for content crawled with Connectivity Hub or Connector Framework.
mode
Query string, Optional
The mode used when loading file.
Options: "" (this is the default), "inline", "ignoremsg"
If set to "inline", the Content-Disposition header of the response is set to "inline", otherwise the header value is set to "attachment".
"ignoremsg" should be used only if the item extension is "msg" or "vcf".
If mode is set to "ignoremsg" when requesting a "msg" or "vcf" file, then the ContentType Header of the response is set to "application/octet-stream", otherwise it is set to "application/msoutlook".
filename
The desired name for the downloaded file.
- source
https://<smarthub-web-app>/_bai/v1/document/load?source=spworks%3A%2F%2F.....
