Specify Recommended Results
What are Recommended Results?
- Recommended results enable you to filter your search results according to the parameters that you specify.
- Shown in the user interface in the 'Filter results by" in the top right corner of the Results page. (See the graphic below)
- These parameters can include:
- Recently viewed
- Most used by me
- What others are viewing
- New results
- Curated results
How to Configure your Recommended Results
The Recommended Results component is embedded in the Analytics Settings module
Modify your HTML page's settings to enable the Recommended Results component for the page
This is done using the UI Builder tool
UI Builder
The easiest and fastest way to insert and customize Recommended Results is via the SmartHub UI Builder.
For more information, see How to Use the UI Builder.
SmartHub administrators can simply click the UI Editor link from the SmartHub Administration page.
Select (double-click) an HTML page such as Results.html page.
BA Insight recommends you use page and folder to modify. Leave the default files as templates.
Example: Customizations/Results.html. Default Results.html is under the top most SmartHub directory.
Select the Advanced mode from the top right of the page.
Select Advanced settings edit.
Scroll down to line 148 (this may vary), which contains the text
SH.AnalyticsSettings.CustomSettings
To access the available Recommended Results settings, click the See Default Settings link in the top right corner.
- Search for the word "recommendedResultsControl" on the page to quickly navigate to the Recommended Results default settings, nested under the AnalyticsSettings component shown below:
- Copy the entire recommendedResultsControl section.
- Go back to your Advanced settings edit tab.
- Paste the copied settings inside section SH.AnalyticsSettings.CustomSettings.
- Modify additional settings as desired.
- Click Save changes.
Click the link Preview <html> file.html at the top of the code editor.
Review your HTML page in the new tab that opens.
Make any necessary changes back in the code editor. Repeat steps 14-18 as necessary.
Click Save changes.
SH.AnalyticsSettings = SH.AnalyticsSettings || {};
SH.AnalyticsSettings.DefaultSettings = {
Enabled: true,
PAXModules: "PAX_PortalModule,PAX_SearchModule,PAX_UserProfileModule,PAX_VisualRefinersModule,PAX_SmartPreviewsModule,PAX_Ratings,PAX_ChatBotModule,PAX_SmartAutomationsModule",
customProperties: "",
showTrackingBehaviorControl: true,
enableGeolocationTracking: true,
artifactPushInterval: 60, //seconds
visitsDuration: 30, //minutes
geolocationTrackingMessage: "We would like to know your location in order to improve your search experience.".toLocaleString(),
trackingBehaviorPropertyName: "BAISmartHubAnalyticsTrackingBehavior",
defaultTrackingBehavior: "0", // 0 - Track; 1 - Do not track; 2 - Track but hide identity
trackingControlFile: "client/pax-tracking-behavior-control", // must have the format used by require.js
recommendedResultsControl: {
showRecommendedResultsDropdown: false,
enableRecommendedResultsControl: true,
title: "Filter results by".toLocaleString(),
messageNotFoundRecommededResults: "Could not find any results for option: ".toLocaleString(),
items: {
"Default": {
value: "0",
label: "Default".toLocaleString()
"RecentlyViewed": {
value: "1",
label: "Recently viewed".toLocaleString(),
lastDays: "5",
maxResults: "100"
"MostUsedByMe": {
value: "2",
label: "Most used by me".toLocaleString(),
lastDays: "5",
maxResults: "100"
"WhatOthersAreViewing": {
value: "3",
label: "What others are viewing".toLocaleString(),
lastDays: "5",
maxResults: "100"
"NewResults": {
value: "4",
label: "New results".toLocaleString(),
lastDays: "5",
maxResults: "100"
"CuratedResults": {
value: "5",
label: "Curated results".toLocaleString(),
lastDays: "5",
maxResults: "100",
"SmartAnalyticsIndex.[AccountName]": "AdditionalProperty.[AccountName]"
parentSelector: ".coveo-results-header" // JQuery selector for parent element(s) where to inject the control.
How to Disable Recommended Results
From within the settings inside section SH.AnalyticsSettings.CustomSettings.
- By default, the following two parameters are set to false and true, respectively:
- Set both parameters to false to disable this feature.
How to Modify or Filter the Recommended Results Display
Procedure:
Follow steps 1-9 under the UI Builder topic, above to access the Recommended Results settings.
The Recommended Results items are stored 5 lines under the
line in the settings file:
Copy the settings nested under the
items: {
line. - Paste the copied settings inside section SH.AnalyticsSettings.CustomSettings.
- Modify additional settings as desired. Use the tables below in the topic "Recommended Results Display Settings."
Make any necessary changes back in the code editor. Repeat steps 5-8 as necessary.
Click Save changes.
Use the following options to modify, or add a filter to, the Recommended Results display:
Option (Value: number used for the “Filter results” drop-down) | Description |
Recently viewed (value: "1" ) |
Displays the results (Max Results) opened in the lastDays . |
Most used by me (value: "2" ) |
Displays the top (Max Results) results opened by me in the lastDays . |
What others are viewing (value: "3" ) |
Displays the top (Max Results) results opened by other users in the lastDays . |
New results (value: "4" ) |
Displays the top (Max Results) results opened by other users in the lastDay and the documents that have been modified in the last week. |
Curated results (value: "5" ) |
Displays the top (Max Results) results opened by users in the same department |
Parameters
Use the following parameters:
Parameter | Description |
value
This the OptionId from the Recommended Results Configuration JSON. |
This is the display name of the filter. |
lastDays
This determines how recent the results are. |
maxResults
This is the maximum number of results. |
How to Add a New Filter
To add a new filter, add a new item in the items
array and specify your parameters.
See the following example:
{ value: "value_example", label: "title_example", lastDays: "lastDays_example", maxResults: "maxResults_example" },
Custom Recommended Results
If you need a custom recommended results on your page, use the following procedure.
- Go to Analytics Configuration page.
Add a new recommended result, using the format from the below example, in the Recommended Results Configuration Json setting.
For example, if you useID 100:
Analytics config file: Recommended Results blockCopy{
"OptionId": "100",
"QueryTemplate": {
<your custom query to Elastic goes here, it can use lastDays and any other custom parameter as needed> },
"QueryTransformation": "(%ORIGINALQUERY%) AND (%RECOMMENDEDITEMS%)"
In your custom HTML page settings, add a new item in the
items
array and specify your parameters such as shown below.Note thatValue
settings maps to Option ID.CopyrecommendedResultsControl:{
items:{
“myCustomResults”: {
Value: ”100”,
Lastdays: ”10”,
maxResults: ”10”,
customParam: ”customparamvalue”
Finally, add Content-by-Search on a page with the Option ID:
Content by SearchCopy<div class="CoveoContentBySearch"
data-query-text="{SA.RecommendedResults.100}"
data-source-id="b29924a9-ec32-4c10-8892-a544b69ee121"
data-results-per-page='5' data-hide-until-first-query="false">
