User Profile Service
General Request Headers
- type: HTTP Method types for UserProfileService:
GETandPOST. - url: By default, the path to service is: /_bai/v1.0/userprofile
- headers: You must specify
X-SH-Authorizationin order to authenticate with SmartHub. - contentType: What is being sent to the
server.application/json;charset=utf-8is used byGetProperties/SetPropertiesGetPictureuses the default value.
- dataType: What you expect back from the server. In our case, this is a JSON file.
- data:
GetProperties: You can send a total of three parameters:userName(string): This is the name of the user you want to make the request for.If this parameter is missing, it will take identity of the current user.properties(List<string>): This is the list of properties or property that you want to request. By default, the service is going to retrieve all of them: properties from provider + personalized store.personalizedStoreOnly(bool): You can choose to skip the provider and get the values just from the personalized store only (this will decrease the request time). By default, this value is set tofalse.
- SetUserProfileProperties: Only one parameter must be specified:
properties(Directory<string, string>). Specify a collection of properties and their values. - GetUserPicture: username is the only parameter required by this method.
- crossDomain: Default: false for same-domain requests, true for cross-domain request.
Example: Get all user properties
$.ajax( {
type: "POST",
url: url + "/properties",
headers: {
'X-SH-Authorization': 'Bearer ' + token
contentType: "application/json; charset=utf-8",
dataType: "json",
crossDomain: true
Example: Get a list of user properties
This request is only going to retrieve the "PropertyName" property, if it exists.
var properties = [ "PropertyName" ];
$.ajax( {
url: url,
type: "POST",
headers: {
'X-SH-Authorization': " Bearer " + token
data: JSON.stringify( {
properties: properties
dataType: "json",
crossDomain: true
Example: Getting just personal properties
personalizedStoreOnly set to true tells the service to skip calling the provider and just grab the data in the personalized store.
$.ajax( {
url: url,
type: "POST",
headers: {
properties: properties,
personalizedStoreOnly: true
dataType: "json",
crossDomain: true
Example: Get a user picture
var xhttp = new XMLHttpRequest( );
xhttp.open( "GET", url + "/picture", true );
xhttp.setRequestHeader( "X-SH-Authorization", "Bearer " + token );
xhttp.responseType = "blob";
xhttp.onreadystatechange = function ( ) {
if ( this.readyState == 4 && this.status == 200 ) {
var blob = new Blob( [ this.response ], {
type: "image/png" } );
window.URL.createObjectURL( blob );
xhttp.send( );
