Using the UI Editor
Using the UI Editor
Selecting a Page for editing
When accessing the UI Editor via the Editor button from the admin page you are presented with a list of available pages. Double-clicking any of these pages will select it for editing. When accessing the UI Editor via the Edit Page button, the current page is selected automatically for editing. You can change the currently selected page by going to the Select a page tab and double-clicking on the desired page from the list.
Basic Mode
In Basic Mode, the designer can customize several existing SmartHub components and can create a theme for the selected page.
The available options are:
- Edit refiners
- Configure search verticals
- Customize type ahead
- Brand the page
Capabilities:
From the Edit refiners tab, the designer can create a new refiner and edit, or remove an existing one. The refiners can also be reordered by drag and drop.
From the Configure search verticals tab, the designer can create, edit, or remove a search vertical. The search verticals can also be reordered by drag and drop.
From the Customize type ahead tab, the designer can customize the available TypeAhead Providers.
From the Customize ContentContainers tab, the designer can customize the ContentContainers available on the page.
From the Brand the page tab, the designer can update the page logo and customize the default color scheme for the selected page.
Advanced Mode
In Advanced Mode, the designer can fully edit the selected page in an embedded text editor. The available options (tabs) are:
- Advanced HTML edit
- From here the designer can fully alter the HTML structure of the page just like editing the physical page on the disk.
- Advanced CSS edit
- From here the designer can create/update the theme for the selected page.
- Advanced settings edit
From here the designer can update the custom settings file that it is used for that page.
Interacting with the UI Editor
The UI Editor uses a new settings mechanism. If you are accessing the UI Editor after a SmartHub upgrade the existing page settings must be upgraded. This is done automatically by UI Editor, but only if the designer chooses. When accessing a page that uses an older model of page settings, a notification appears. If the designer clicks on the Upgrade button, the existing settings are updated to the new format behind the scenes.
In the case that the page is not updated to use the mechanism, UI Editor capabilities are disabled. To enable the disabled capabilities, click the Upgrade link to perform an upgrade.
UI Editor also has some additional action buttons to simplify the editing process:
Preview Results: This opens the edited page in a new tab to preview any implemented changes. This button is available both in Basic and Advanced mode
See Default Settings: This shows all the default settings for the SmartHub modules. This button is available only on the Advanced settings edit tab in Advanced mode
Advanced editor actions: This button is available only in Advanced Mode. The available actions are:
Search/Replace: Persistent dialog for improved search/ eplace.
Go to line: Dialog for jumping to the specified line
Undo
Redo
Format selection
Insert tab
Remove tab
Comment / Uncomment selection
Toggle full-screen
Interacting with Pages and Directories
Creating Custom Pages
Many clients choose to create new pages in order to implement their customizations. This also prevents default files from being overwritten at upgrade time
You can create a custom web page one of two ways:
Create a brand new, empty page of a given page type (Landing, Index, or Results page)
Duplicate an existing page such as Index.html, Landing.html or Results.html
Duplicate the web page within its own folder and give it a custom name
Useful if you have an existing page that works well as a template to build on/modify
The native, original file (Index.html, for example), remains unchanged and serves as a template. See Basic Functions below for illustrations and additional details
To create a custom page, do the following:
Select the folder icon next to your SmartHub folder and create a new directory.
In the Create a new directory dialog box, enter a name for your new directory. For example, "MyCompany"
From the new directory, select the + icon and select New Page.
Select the Page Type:
Landing
Index
Results
Enter a name for the new HTML page. For example, "MyCustomResultsPage.html"
Click Apply.
Basic Functions
From the file picker the designer also create:
- A new directory
- A new HTML page
When creating a new page you have three options for the page type:
- Landing Page:
- Based on the out-of-the-box landing.html page available in SmartHub
- Index Page:
- Based on the out-of-the-box Index.html page available in SmartHub
- Results Page:
- Based on the out-of-the-box Results.html page available in SmartHub
Along the option to create new pages or directories, the designer can also:
Rename a file or a directory:
The designer can change the name of a file or a directory, automatically updating the settings and the theme for that page/ pages from the directory
Duplicate a file or a directory:
The designer can duplicate a file or a directory, automatically duplicating the settings and the theme for that page/ pages from the directory
Delete a file or a directory:
The designer can delete a file or a directory, automatically deleting the settings and the theme for that page/ pages from the directory
UI Editor Settings
These settings can be changed from the web.config file found in the SmartHub root directory.
Settings |
Default | Description |
| PageSettingsFolder | ~/_content// | The default location for the new page settings file. |
| PageThemeFolder | ~/_content// | The default location for the new page theme file. |
| EditorPagesFolder | ~/ |
| EditorBlacklistedFolders | "" |
Create a Custom Page
This also prevents the file from being overwritten at upgrade time.
Access the UI Editor
From the Page Selector create a new folder with the desired name
Create a new page in the new folder.
Choose one of the three available starting pages as a starting point:
Landing
Index
Results
Display Template
Continue editing the new page via the UI Editor.
Create a Display Template
Many clients choose to create new display templates in order to implement their customizations and prevents the file from being overwritten at upgrade time.
Open the UI Editor.
From the Page Selector, Click to folder icon to create a new folder with your desired name
Click the + icon to create a new page in the new folder.
In the Page Type section, select Display Template page. An empty HTML file is added.
Continue editing the new display template via the UI Editor.
