How to Set Up and Configure the Jive Connector
The Jive web service connector sends requests to your Jive source system from the BA Insight Connector Framework. For best performance, the connector should be installed on a Windows server near (geographically close to) the source system. If necessary, it can be installed on any of the app servers in your SharePoint farm.
All BA Insight connectors can be downloaded from the Upland Right Answers Portal under Knowledge > BA Insight > Product Downloads > Connectors. This connector is installed with the same generic steps as any BA Insight connector.You must satisfy the Prerequisites for your connector before installing. The configuration specifics are detailed below.
Verify the Installation
To verify the installation, follow these steps:
- Enter the URL to the DataConnector, which is in the following form: http://<host>:<port number>/dataconnector.asmx where <host> is the FQDN, Host name, or IP of the server where the connector is installed, and <port number> is the port number chosen previously.
- A DataConnector page displays, confirming that the installation was successful.
