Configure the conversational search module for your SmartHub pages
Overview
The Conversational Search module allows you to integrate a Conversational Bot in a SmartHub or external web page. The conversational search module supports three types of integrations:
  • SinglePage: This integration runs standalone in a SmartHub page, taking up entire page.
  • Assistant: This integration is added to a results page and is rendered on the side panel. The user has the ability to manually collapse and expand the panel.
  • Hybrid: This integration combines the SinglePage and Assistant integrations by adding the conversational bot to a results page and using the query from the main SmartHub search box to start a conversation. This integration is usually rendered in the middle of the page, above the search results.
The conversational search module offers additional actions known as ContentActions. For more information, see the Conversational Bot Parameters.
Additionally, if you would like to use the functionality of traditional SmartHub search and SmartHub conversational search from a single page, you can configure a content container module through the UI Editor to display related document results in a split-screen view. After doing so, you must enable the SplitScreenMode parameter and configure the RelatedDocuments parameters.
Configuration procedure
The Conversational Search Module can be configured or modified using the UI Editor in Advanced Mode. For information about how to access the UI Editor as well as who can access it, see Using the UI Editor.
SH.ConversationalSearch.CustomSettings = {
    "ConversationalSearchBot": { <settings object described in table below>}
Conversational Bot ID
Setting Description Default value
This setting specifies an ID for your conversational bot. When configuring your Conversational Bot Settings, this field contains the Conversational Bot Parameters.
Enabled
This setting enables or disables the Conversational Bot. The possible values for this setting are:
  • true
  • false
true
EnableFeedback When this setting is set to true, the ConversationalSearchFeedback module will be enabled. This allows users to submit feedback for any answer provided by the conversational search bot by clicking the Like or Dislike button for the answer. true
DisableOnRefinersInteraction
When this setting is set to true, the bot will not trigger a new question if the user applies or has applied search refiners on the page.
This setting only applies for Hybrid and Assistant integrations
true
ParentSelector This setting specifies the parent selector that is used for appending the compiled template of the Conversational Bot. ".conversationalSearch"
ConversationalBotName This setting displays the name of the Conversational Bot, as configured in the SmartHub administration portal. For more information, see Configure the conversational bot settings. "Conversational Bot"
ChatHistoryMessagesLimit This setting specifies the Chat History messages limit 5
ChatHistoryCharactersLimit This setting specifies the Chat History characters limit. 500000
MaxRecentConversations This setting specifies the maximum number of conversations that the user can have saved when the Saved Conversations feature is enabled. 10
MaxPinnedConversations This setting specifies the maximum number of conversations that the user can have pinned when the Saved Conversations feature is enabled. 10
TextRenderingMode
This setting instructs the Conversational Search page on how to render the bot response. This setting has the following 3 possible values:
  • character: This instructs the page to render each letter of a received chunk, one by one.
  • chunk: This instructs the page to render each chunk of the bot response, one by one.
  • nonstream: This instructs the page to render the full bot response all at once. This will use the FullMessage event instead of the Message event.
"character"
Mode
This setting specifies the mode that the Conversational Bot uses. Possible values are:
  • SinglePage
  • Assistant
  • Hybrid
For more information, see the overview section.
"SinglePage"
SinglePageSearchTemplatePath This setting specifies the path to the template used when rendering in SinglePage Mode. SH.RootLevelURL + "/modules/ConversationalSearch/templates/s inglePageConversationalSearchTemplate.ht ml"
SplitScreenMode This setting enables split screen mode for the Conversational Search. When enabled, documents that are related to the chat conversation are displayed alongside the chat interface. true
RelatedDocumentsContainerId This setting specifies the id of the content container that renders the related documents pane. "ConversationalSearchCBS"
DocumentPathMetadata
This setting specifies the metadata that is used to sort the received chunks and in generating the value for {DocumentPathRestrictions} in the RelatedDocumentsQueryTemplate setting.
{DocumentPathRestrictions} represents a list of property restrictions based on the DocumentPathMetadata setting. For example, (clickUri="some/path/to/document.pdf" OR clickUri="another/path/to/document.pdf")
"clickUri"
This setting specifies the QueryTemplate that is used by the ContentContainer as defined in the RelatedDocumentsContainerId setting.
Note the following:
  • {DocumentPathRestrictions} represents a list of property restrictions based on the DocumentPathMetadata setting. For example, (clickUri="some/path/to/document.pdf" OR clickUri="another/path/to/document.pdf")
  • {ConversationalSearchSources} represents the list of backends where the chunks were used to generate the response. For example, "Backend1;Backend2"
  • {DocumentPathRestrictions} and {ConversationalSearchSources} are automatically replaced with values computed by the Conversational Search module based on the received chunks. The keywords are not required.
"({DocumentPathRestrictions}) FederatorBackends:\"{ConversationalSearchSources}\""
AssistantSearchTemplatePath This setting specifies the path to the template used when rendering in Assistant and Hybrid Mode. SH.RootLevelURL + "/modules/ConversationalSearch/templates/a ssistantConversationalSearchTemplate.html"
HybridModeCollapseStatus
This setting specifies the state that the Conversational Bot will render in during Hybrid Mode. The possible values are:
  • Collapsed
  • Expanded
"expanded"
HybridModeSearchEvent This setting specifies the event that the Conversational Bot will listen for in order to start a conversation while in hybrid mode. "newQuery"
HybridModeSearchTabIds
This setting specifies a semicolon separated list of search vertical IDs to restrict the conversational search query to one or multiple search verticals. By default, this setting is empty, meaning that the query will execute on all search verticals.
For example, HybridModeSearchTabIds: "b29924a9-ec32-4c10-8892-a544b69ee121;459dd1b7-216f-4386-9709-287d5d22f568"
UserReplyTemplatePath This setting specifies the path for the template that renders the user message. SH.RootLevelURL + "/modules/ConversationalSearch/templates/u serReplyTemplate.html"
UserAvatarPath This setting specifies the path for the avatar used by the user. By default the avatar is the user’s profile picture. ""
BotLoadingTemplatePath This setting specifies the path for the template that renders the loading animation for the bot before a reply. SH.RootLevelURL + "/modules/ConversationalSearch/templates/b otLoadingTemplate.html"
BotReplyTemplatePath This setting specifies the path for the template that renders the bot message. SH.RootLevelURL + "/modules/ConversationalSearch/templates/b otReplyTemplate.html"
BotAvatarPath This setting specifies the path for the avatar used by the bot. SH.RootLevelURL + "/modules/chatbot/images/chatbotIcon.png"
SourceDocumentsTemplatePath This setting specifies the path for the template that renders the list containing the source documents for the generated answer SH.RootLevelURL + "/modules/ConversationalSearch/templates/s ourceDocumentsTemplate.html"
ShowContentActions
This setting allows you to enable Content Actions. The possible values are:
  • true
  • false
true
ContentActionsTemplatePath This setting specifies the path for the template that renders the Content Actions. SH.RootLevelURL + "/modules/ConversationalSearch/templates/c ontentActionsTemplate.html"
ContentActionsEvent
This setting specifies the event that triggers the Content Actions rendering. The possible values are:
  • beforeUserInteraction
  • newConversation
"beforeUserInteraction"
ModuleDetails This setting is used to configure different text snippets from the module. -
SmartPreviewsDetails
This setting is used to configure conversational search and Smart Previews integration.
If you are using document previews you must be using SmartHub 7.1 and Smart Previews 4.0.x or later.
For more information, see Using SmartPreviews with conversational search.
ModuleDetails Parameters
These settings specify the UI labels and text that the user can customize without creating a new html template.
SearchBoxPlaceholder
This setting specifies the placeholder text for the searchbox
"Search...".toLocaleString()
RefinersAppliedSearchBoxPlaceholder This setting specifies the placeholder text for the searchbox when filters are applied and DisableOnRefinersInteraction is set to true. "Assistant is disabled when filters are applied".toLocaleString()
Send This setting specifies the tooltip for the send button "Send".toLocaleString()
NewConversation This setting specifies the tooltip for the new conversation button "New Conversation".toLocaleString()
Title This setting specifies the visible name when the Conversational Bot is used in Hybrid or Assistant mode. "Assistant".toLocaleString()
Filters This setting specifies the title for the filters window "Filters".toLocaleString()
ClearFilters This setting specifies the label for the clear filters button "Clear Filters".toLocaleString()
ApplyFilters This setting specifies the label for the apply filters button "Done".toLocaleString()
Disclaimer This setting specifies the Upland Disclaimer for using Generative AI. "The BA Insight Smart Hub Conversational Chat Bot provided by Upland Software, Inc. allows our customers and their users to access certain services, including AI- powered tools and resources provided by third parties with whom our customers may have existing contractual relationships, through integrations with Upland Software's applications and online services. As such, as between you and Upland, you acknowledge and agree to use these AI tools or resources at their own risk and discretion. The decision to implement or rely on these tools rests solely with you. As between you and Upland, you accept full responsibility for any consequences, damages, or losses that may arise from their use, and it is your responsibility to assess and evaluate the suitability, compatibility, and potential risks associated with the use of these tools for your specific needs. You should exercise caution and undertake proper due diligence before using any AI tool or resource.".toLocaleString()
ErrorMessage
This setting specifies the error message that the Conversational Bot will show when there is an error with the Conversational Search Service.
"Something went wrong. Please contact the administrator.".toLocaleString()
SourceDocumentsMessage This setting specifies the message shown before listing the source documents. "This information was extracted from:".toLocaleString()
LikeButtonLabel This setting specifies the label value for the Like button. ' '
LikeButtonHoverLabel This setting specifies the label value for the Like button when it is hovered over. 'Like'
DislikeButtonLabel This setting specifies the label value for the Dislike button. ' '
DislikeButtonHoverLabel This setting specifies the label value for the Disike button when it is hovered over. 'Dislike'
DetailsMessage This setting specifies the text that precedes the feedback options in the feedback window. 'Tell us more about the answer.'.toLocaleString()
AditionalDetailsMessage This setting specifies the text that precedes the additional details text box in the feedback window. "Please provide some details about the issue:".toLocaleString()
CancelButtonLabel This setting specifies the label value for the Cancel button. "Cancel".toLocaleString()
SubmitButtonLabel specifies the label value for the Submit button. "Submit".toLocaleString()
SmartPreviewsDetails Parameters
These settings allow you to configure Smart Previews for your conversational search instance. For more information, see Using SmartPreviews with conversational search.
Enabled
This setting enables or disables the Smart Previews integration with Conversational Bot. The possible values for this setting are:
  • true
  • false
true
DocumentSourceTitleField This setting specifies the field from the source system that contains the document title. "title"
DocumentSourceUrlField This setting specifies the field from the source system that contains the document url. "clickUri"
DocumentChunkBodyField This setting specifies the field from the source system that contains the body of the document chunk. ESC_Chunk_Body"
ConversationalSearchFeedback Parameters
These settings allow you to configure the feedback feature for your conversational search instance. For more information, see Applying feedback to your conversational search responses.
Title
This setting specifies the title of the feedback modal window.
"Feedback"
ButtonTemplatePath This setting specifies the path to the html template for the Like and Dislike buttons. SH.RootLevelURL + "/modules/ConversationalSearchFeedback/ templates/buttonTemplate.html"
ContentModalTemplatePath This setting specifies the field from the source system that contains the document url.
SH.RootLevelURL + "/modules/ConversationalSearchFeedback/ templates/conversationalSearchFeedbackModalTemplate.html"
MailTo This setting specifies the email address where the feedback will be sent. "search@bainsight.com"
BodyEmailTemplate
This setting specifies the template for the email body. The following placeholders can be used:
  • {Answer} - The answer provided by the search bot.
  • {Question} - The question asked by the user.
  • {Status} - "Liked" or "Disliked" depending on the feedback.
  • {Details} - Additional details provided by the user. For example, the liked or disliked reasons selected from the presented lists and the additional details provided by the user via the comments section.
"The answer: \"{Answer}\" provided by the Conversational Bot for the question: \"{Question}\" was \"{Status}\".\n {Details}."
DislikedReasons The setting specifies a list of reasons for disliking an answer. The user can select one or more reasons from this list.
    "I should not see this (access issue).".toLocaleString(),
    "Old/Outdated content.".toLocaleString(),
    "Innapropriate content.".toLocaleString()
LikedReasons This setting specifies the list of reasons for liking an answer. The user can select one or more reasons from this list.
    "The answer was correct".toLocaleString(),
    "The answer was informative".toLocaleString()
SkipModalForLikes If this setting is set to true, the feedback modal window will not be shown when an answer is liked. true
SkipModalForDislikes If this setting is set to true, the feedback modal window will not be shown when an answer is disliked. false
SkipEmailForLikes If this setting is set to true, the email containing the feedback will not be sent when an answer is liked true
SkipEmailForDislikes If the setting is set to true, the email containing the feedback will not be sent when an answer is disliked false
ModuleDetails This setting specifies the UI labels and text that the user can customize without creating a new html template. -
ChatWithDocument Parameters
These settings allow you to configure the chat with documents feature for your conversational search instance. For more information, see Using chat with documents.
Enabled
This setting enables or disables the chat with document feature for conversational search. The possible values for this setting are:
  • true
  • false
true
EnabledBasket This setting enables or disables the basket for the chat with document feature, allowing users to add selected documents to their basket, which they can then use to filter their conversational search chat when needed. The possible values for this setting are:
  • true
  • false
true
ChatBotMode
This setting specifies the conversational search mode that is applied. The possible values for this setting are:
  • SinglePage
  • Hybrid
"SinglePage"
BasketKey This setting specifies the name of the SmartHub basket, as configured in the SmartHub Basket instructions. ".basketButton"
BasketLabelChatWithAllDocuments This setting specifies the text that is displays for the "Chat with all documents" control in the SmartHub basket. "Chat with all favorite documents"
BasketLabelChatWithSelectedDocuments This setting specifies the text that is displays for the "Chat with selected documents" control in the SmartHub basket. "Chat with selected documents"
ConversationalSearchBotID This setting specifies the ID for your conversational bot, as configured in the conversational search instructions. "ConversationalSearchBot"
WarningMessage This setting specifies the text that is displays when a user attempts to add the same document to a chat session. "This document is already active in the chat session"
WarningMessageSelector This setting specifies where the warning message will render on the page. ".sh-row-body.sh-body-grid.coveo-main-section .sh-column-right"
ConversationalSearchPagePath This setting specifies the path to your conversational search page. "/ConversationalSearch.html"
DocumentTitleProperty This setting specifies the field to use to populate the title of the document. "title"
DocumentExtensionProperty This setting specifies the field to use to populate the file extension of the document. "FileExtension"
PropertyUsedForRestriction   "clickUri"
InfoMessageTemplatePath This setting specifies the path to the info message template file. SH.RootLevelURL + "/modules/ChatWithDocument/templates/InfoMessageTemplate.html"
Note the following:
  • The html elements specified in the ParentSelector setting will have to exist in the html of the page. The elements can be added via the UI Editor in Advanced Mode.
  • When specifying SmartPreviewsDetails parameters, you must update the property values (DocumentSourceTitleField, DocumentSourceUrlField, and DocumentChunkBodyField) according to the source system you are working with.
    • These properties must match the ones configured in the Original Document Properties field of the conversational bot settings to ensure SmartPreviews functions correctly.
  • The split screen feature is available only when the Conversational Search Bot is running in the SinglePage mode. In desktop mode, queries are executed only when the Related Documents side panel is expanded.
  • Changes made at ContentContainer level are still supported and are done through the UI Editor.
    • The following ContentContainer settings should not be changed: TriggerNewQueryOn and QueryTemplate.
Upgrading from SmartHub 7.2 Conversational Search
When upgrading your from SmartHub 7.2 to a later version, there are a few steps you must make to ensure your conversational search integration is upgraded successfully. The following steps outline how you can upgrade from the legacy Conversational Search integration to the new Agentic RAG Conversational Search configuration, preserving your existing settings and minimizing manual reconfiguration.
  1. Open the Smarthub 7.2 Administration site.
  2. Click General Settings and locate the Import/export settings section.
  3. Click EXPORT SETTINGS
  4. Complete the SmartHub 7.3 upgrade following the standard upgrade procedure.
  5. Open the Smarthub 7.3 Administration site.
  6. Click General Settings and locate the Import/export settings section.
  7. Import the exported FederatorConfiguration.xml file from step 3.
  8. Verify the imported Conversational Search configuration. Some manual updates are required. Review the following sections to determine which settings must be adjusted manually:
    1. LLM Configuration:
      1. Name: Specify an appropriate name for the LLM configuration.
      2. Maximum Context Tokens: Specify the correct maximum window context tokens for the used AI Model. This value should include input tokens, output tokens, and control tokens.
      3. Configure any optional settings as needed.
    2. Agents Management:
      1. Orchestrator: Update the Retrieve Answer for Standalone Request action by migrating any applicable custom information previously defined in the Question Rewrite Instructions setting into the new configuration.
      2. Query Processor: No upgrade changes are required.
      3. Response Generator: No upgrade changes are required.
      4. Result Insights: Update the Suggest Followup Questions action by migrating any applicable custom information previously defined in the Follow Up Question Generation Template setting into the new configuration.
    3. Chatbots Configuration:
      1. Conversational Bot Description: Provide a brief description of your chatbot.
      2. Maximum Output Tokens: Specify the maximum length of text your large language model (LLM) can generate in a single response.
Note: If the Configuration folder from SmartHub 7.2 is dragged and dropped in SmartHub 7.3, the Conversational Search configuration won't be ported, and the following error will be shown: "[queryid:] ERROR - [ConversationalSearchService.GetAnswerStreamContent:187][ConversationalSearchService] GetAnswerStreamContent failed. System.Exception:[ConversationalSearchService] Invalid Conversational Bot Name - configuration not found"
Using Conversational Search filters
You can configure filters that users can apply to their Conversational Search chats. These filters work similar to SmartHub refiners, but they are applied to the knowledge sources that are used by your chosen LLM to provide answers. For example, if you filter by filetype:pdf, the LLM will only use pdf files to find an answer. Once configured, users will be able to apply a filter and select the desired value from the ConversationalSearch.html page. When filters are applied, the number of filters is displayed.
After applying filters, they will be taken into consideration when a subsequent question is asked. They will not be used for any question that was asked before the filter was applied. Users also have the option to clear their applied filters, and all filters will be cleared when a new conversation is started or the page is refreshed.
Limitations
Note the following limitations with Conversational Search filters:
  • Conversational Search refiners are only supported on the standalone conversational search page. For example, "ConversationalSearch.html". Conversational Search refiners are not supported when integrated in the SmartHub results page, due to conflicts with page refiners.
  • Currently, only one facet container is supported per page.
  • All refiner types are compatible, with the following limitations:
    • The refiners must be On Demand facets. In other words, the data-preload-values refiner setting property must be false.
    • The results count must be disabled. In other words, the data-show-count refiner setting property must be false.
    • Each facet must have a Conversational Search Bot Id assigned. Only one Conversational Search Bot Id is supported per page. The value must match the bot ID in the Conversational Search settings. For example, using the example in the Configuration procedure section, the Conversational Search Bot Id is “ConversationalSearchBot”.
Add and edit your Conversational Search filters
  1. When configuring Conversational search, ensure that the mode is set to SinglePage and there are no additional search refiners enabled.
  2. In the SmartHub UI Editor, click Advanced Mode > Advanced HTML Edit.
  3. In the HTML settings file, add the following line that corresponds to the facet panel:
    <div class="coveo-facet-column"></div>
  4. The FederatorBackends parameter must be updated for the data-expression attribute in the CoveoTab element to correspond to the selected Search Engines from the Conversational Search Bot settings.
    <a class="CoveoTab" data-icon="fas fa-globe" data-id="b29924a9-ec32-4c10-8892-a544b69ee121"
    data-expression='{searchboxquery} FederatorBackends:"BackendA;BackendB"' data-caption="Everything" data-automation-id="everythingVertical"></a>
    The search engines that are specified in this parameter MUST be enabled in the Search Engines section of the SmartHub General Settings.
  5. Return to Basic Mode in the UI editor and select the Refiners tab. This tab allows you to add a new refiner, but you must ensure that you follow the limitations stated above.
  6. Click Apply and Save.
The following are the default facets that are configured on the ConversationalSearch.html page:
    <div class="CoveoFacet" data-conversational-search-bot- id="ConversationalSearchBot" data-default-state="collapsed" data-title="Result type" data-field="@filetype" data-lookup-field="@filetype"
    data-available-sorts="occurrencesdescending,occurrencesascending, alphaascending, alphadescending"
    data-enable-settings="false" data-searchbox-position="bottom" data- preload-values="false" data-enable-toggling-operator="false"
    data-enable-facet-search="true" data-show-apply-button="false" data-is-dynamic- facet="false" data-use-radio-buttons="false" data-general-apply-button="true"
    data-show-count="false">
    </div>
    <div class="CoveoFacet" data-conversational-search-bot- id="ConversationalSearchBot" data-default-state="collapsed" data- title="ContentSource" data-field="@ContentSource"
    data-lookup- field="@ContentSource" data-available-sorts="occurrencesdescending,occurrencesascending,alphaascending,alphadescending"
    data-enable-settings="false" data-searchbox-position="bottom" data- preload-values="false" data-enable-toggling-operator="false" data-enable- facet-search="true"
    </div>
    <div class="CoveoFacetDatepicker" data-conversational-search-bot- id="ConversationalSearchBot" data-start="auto" data-end="auto" data-default- state="collapsed" data-title="Modified Date"
    data-field="@date" data-lookup- field="@date" data-available-sorts="occurrencesdescending,occurrencesascending,alphaascending,alphadescending" data-preload-values="false">
    </div>
    <div class="CoveoFacet" data-conversational-search-bot- id="ConversationalSearchBot" data-default-state="collapsed" data- title="Display Author" data-field="@DisplayAuthor"
    data-lookup- field="@DisplayAuthor" data-available-sorts="occurrencesdescending,occurrencesascending,alphaascending,alphadescending" data-enable-settings="false"
    data-searchbox-position="bottom" data- preload-values="false" data-enable-toggling-operator="false" data-enable- facet-search="true" data-show-apply-button="false"
    data-is-dynamic-facet="false" data-use-radio-buttons="false" data-general-apply-button="true" data-show-count="false"></div>
</div>
