Remove a Task from My Work
Users can manually remove Tasks from their "My Work" panel on the Eclipse PPM Home page.
There are two easy ways to remove a Task from your "My Work" panel:
To remove a Task from My Work from the Eclipse PPM Home page:
  1. Navigate to the Eclipse PPM Home page.
  2. Select the "Tasks" tab from your "My Work" panel:
    Click image to enlarge.
  3. Open up the drop-down menu of the Task you would like to remove:
  4. Select Remove from My Work.
After selecting Remove from My Work, the Task will no longer appear on your "My Work" panel.
Note: The removed Task will still appear on your "My Project Work" tab on the Project Home page.
To remove a Task from My Work from the Project Home page:
  1. Navigate to a Project Home page.
  2. Select the "Tasks" tab from your "My Project Work" panel:
After selecting Remove from My Work, the Task will no longer appear on your "My Work" panel on the Eclipse PPM Home page.
Note: The Task will still remain on your "My Project Work" panel on the Project Home page if the Task is assigned to you. If it was not, it will disappear from the panel after you refresh the page.
