About HP LAN Fax Connector
The HP LAN Fax connector allows the HP Capture and Route server to process and deliver outbound fax messages originating in a HP 9100C Digital Sender device.
Note: You can configure the HP LAN Fax connector for multiple HP Digital Senders as long as all the devices share the same \HPFSCAN folder with the server.
The advantage of using this connector is that you can use the server to route fax messages from several HP devices and maintain centralized information about all outbound messages in the network.
Before you begin
HP LAN Fax connector requirements
You must have the following installed and configured before you can install an HP LAN Fax connector.
Note: Read the documentation from HP on how to configure a Digital Sender device to a LAN fax at: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bps53327&jumpid=reg_R1002_USEN.
HP LAN Fax connector workflows
Using the HP LAN Fax connector to send a fax
  • A user prepares and sends a fax using the HP multi-function device.
  • The fax document is delivered from the device to the \Shared\LanFax\In\ folder (a shared folder that is accessed by the device and the server).
  • The server detects the fax, picks it up, and processes it for delivery.
  • After the fax is processed, delivery status is sent back to the HP device.
Using the HP LAN Fax connector to send a fax to a third party fax server
  • The server detects the fax and matches the routing rule to send faxes to the HP LAN Fax connector directory that is monitored by the third party fax services for delivery.
Accessing HP LAN Fax connectors
To access HP LAN Fax connectors
  3. Select Connectors. The details pane lists the connectors that are licensed with your server.
  4. Double-click the HP LAN Fax connector to view its properties.
Adding a HP LAN Fax Connector
