About QuickFlows
QuickFlows are templates that Administrators can use to quickly and easily configure workflow rule sets, buttons, devices and more in one centralized location. Each QuickFlow template is presented in a wizard that leads you through a series of steps which include:
  • Requirements – This step checks the HP CRServer version, connector, device and other types of configurations. See Before you begin for more information.
  • Naming – This step is used to specify a unique workflow name and add a description. The description is optional.
  • Scan – This step is used to specify Scan button details and properties.
  • Deliver to – This step is used to specify delivery details.
  • Job Properties – This step is used to add, edit, remove, and move job property details in a specific order.
  • Notifications – This step is used to specify a notification type and details.
Before you begin
A minimum requirements check is done when you create a new QuickFlow. A message appears if the minimum requirements are not met. You will not be able to continue and configure the QuickFlow until the minimum requirements pass this check.
Tip: Ensure you have the appropriate connectors and devices configured before you begin.
Access QuickFlows
QuickFlows are in the Server Administrator Console.
To access QuickFlows
  1. Open theServer Administrator Console. The Server Administrator Console window appears.
  2. Click the Expand arrow (>) next to Server Administrator. The Server name appears.
  3. Click the Expand arrow (>) next to the Server name. The Server tree appears.
  4. Click QuickFlows. The QuickFlows window appears.
Tip: Any of the panes can be expanded to view more information if the QuickFlows window is resized. See how below.
To expand a pane
  1. Place the mouse pointer on the pane border.
  2. Click the pane border, if necessary. The mouse pointer becomes a double-arrow.
  3. Drag the double-arrow to the right or left  to view more or less information.
Access QuickFlows Templates
You can access the QuickFlows templates by using the New menu in the Server Administrator or Actions pane.
To access the QuickFlows templates
From the Server Administrator pane
  1. Go to the Server Administrator pane.
  2. Right-click QuickFlows. The QuickFlows menu appears.
From the Actions pane
  1. Go to the Actions pane.
  2. Click More Actions. The QuickFlows menu appears.
Creating  a QuickFlow
QuickFlows in Action
