About SMTP Connector
The SMTP connector enables communication between the HP Capture and Route Server and a SMTP mail server. With the SMTP connector installed, users can send and receive messages using network scanning devices, End User Interface or any SMTP email client program. The SMTP connector is used as a standardized approach in mail communication which eliminates the need for additional preparatory interfaces.
Note: Users must send their message using a qualified SMTP address format. For instructions, see SMTP connector one-off address format.
The SMTP connector also can be configured for DID lookups. This setting identifies information about the intended recipient for inbound faxes and retrieves and applies sender information on a cover page for an outbound message.
SMTP connector requirements
You must have the following installed and configured before you can install the SMTP connector.
  • HP Capture and Route Server with all the required configurations
  • SMTP server
  • Internet Information Services (IIS)
  • Virtual SMTP server properties configured with the address of the SMTP server. For instructions, see Configuring virtual SMTP server properties.
Accessing the SMTP connector
You can access the SMTP connector by using the Server Administrator > Connectors node.
To access the SMTP connector
  3. Select Connectors. The Connectors details pane lists the connectors that are licensed with your server.
  4. Double click the SMTP connector to view and edit its properties, if necessary.
Sending SMTP Connector Outbound Messages
Adding a SMTP Connector
Configuring SMTP Connector DID/DTMF Lookup
SMTP Connector One-off Address Format
Configuring SMTP Connector Default Recipient Type and Outbound Rules
