Modifying Folder Properties
You can modify Folder properties by using the Server Administrator > Configuration node.
To modify folder properties
  1. On the Start menu, click HP Capture and Route > HP Capture and Route Server Administrator.
  2. Expand the Server Administrator tree, if necessary.
  3. Click Configuration > Groups.
  4. In the right pane, double-click on the Default group (or applicable group).
  5. Click on the Folders tab.
  6. Highlight the folder name that needs to be modified and click Properties.
  7. On the Edit Folder page make all needed changes and, when finished, click OK.
  8. Click OK again to close the Group page.
Removing a folder
You can remove a folder by using the Sever Administrator > Configurations node.
To remove a folder
  1. Launch the Server Administrator, expand the tree view, and click Configuration > Folders.
  2. In the results node, right-click on the folder of interest.
  3. Click Delete.
Note: Verify that any rules specified for this folder are modified to support the deleted folder.
About Folders
Creating Folders
Configuring Folders
About Printing from Folder
