Installing DMS Libraries Remote Connector
The HP CR connector for DMS libraries routes documents from the server to your company document management system (DMS). When routing an inbound document, the connector for DMS libraries creates a document ID and a pending document in the DMS. When the actual document arrives at the destination DMS server, the connector for DMS libraries locates the placeholder and replaces it with the actual document. After installing the server, you can create an connector for DMS libraries locally. The connector for DMS libraries that is installed on a remote system is called Remote Connector for DMS Libraries.
When scaling an environment with additional connectors or components, always consult Technical Support. The Technical Support team can assist you in correctly identifying potential bottlenecks in the system based on workload and other factors. Moreover, Technical Support can provide helpful information on the overall impact of increasing the speed and efficiency of the system. Performance and stability consulting are also available for a fee. To purchase additional Embedded Directive Manager component licenses, contact your Account Manager. If a detailed analysis of the environment is necessary, Technical Support may recommend a fee-based consultation.
Installing Intelligent Device Client
