Additional Configuration
Additional procedures are available for Fax and Dialogic Brooktrout configurations.
Updating Fax board drivers (for servers with fax capability)
The upgrade supports all new fax board drivers/modules for all supported fax boards including Dialogic Brooktrout Technology SR140, TR1034 series, and TruFax RoHS series.
Note: It is recommended that you update the drivers for your fax boards. If aTechnical Support representative instructs you to update your drivers, use the procedures in this section to remove the drivers and then install new drivers. .
Downloading latest Dialogic Brooktrout drivers
To download Dialogic Brooktrout v6.7.5 x64 drivers
  1. Go to HP CR Support and log in using your customer number.
  2. In the left navigation pane, click Support > Downloads and Docs.
  3. Open the menu, go to theDrivers section. Locate the download.
  4. Click the download link to begin the download. The zip file containing the .msi file and the Release Notes opens.
  5. Select the files and click Extract. Browse to the location where you want to save the file.
  6. Click Extract. The files are extracted and saved to the location you specified.
  7. Name this directory the Boston directory.
Expand to view more information
Upgrading Client Applications
