Creating a Favorite Distribution
Distributions that are used often can be flagged as favorite distributions for quick and easy access from the HP CR Client Dashboard. You can drag and drop files on to your favorite distributions and send with a simple mouse click. No need to select a distribution from the My Distributions list. Favorite distributions are available on the dashboard as soon as you open Web Apps. In addition, you can remove favorite distributions from the HP CR Client Dashboard, if necessary.
Note: Favorite distributions are created from saved distributions. See Creating a Personal Distribution for more information.
To create a favorite distribution
  1. Open HP CR Client from your browser.
  2. Click Distributions. The Distributions tiles appear.
  3. Click My Distributions. The My Distributions list appears.
  4. Select the distribution you want to flag as a favorite distribution. The My Distributions toolbar becomes active.
  5. Click Favorite on the My Distributions toolbar. The star color next to the Distribution name becomes black.
See an example of the My Distributions toolbar with the Favorite button below.
  1. Select the HP CR logo to go back to the HP CR ClientDashboard. Your favorite distribution appears on the HP CR Client Dashboard.
See an example of the Favorite Distribution tile below.
  1. Drag and drop files to send files to the recipients on your favorite distribution. The Distribution Sent message appears.
See an example of drag and drop files in progress below.
Remove favorite distributions
You can remove favorite distributions that are no longer applicable from the HP CR Client Dashboard.
To remove a favorite distribution
  1. Click Distributions. The Distribution tiles appear.
  2. Click My Distributions. The My Distributions list appears.
  3. Select the favorite distribution you want to remove.
  4. Click Favorite. The Favorite button acts as a toggle button and is used to set or remove a favorite distribution from the HP CR Client Dashboard.
  5. Click the HP CR logo to go back to the HP CR ClientDashboard and ensure the favorite distribution has been removed.
About Distributions
Sharing a Personal Distribution
Creating a Public Distribution
About Distribution Collections
