About Received Faxes and Default RuleSets
The HP CR server attempts to match and determine how to process the following message types.
  • Inbound messages against the Received Faxes Rulesets
  • Outbound messages against the Default RuleSets
Received Faxes RuleSets
The Received Faxes RuleSets specify the following parameters.
  • The criteria identifying which rule to match.
  • The actions to perform.
  • Any failover actions, if needed.
Accessing Received Faxes RuleSets
To access the Received Faxes RuleSets
  1. In the Server Administrator, expand RuleSets.
  1. Select RuleSets > Received Faxes. The details pane lists the default Received Faxes rules created when you installed the server.
  2. Select a rule. The Rule Properties dialog box appears.
  3. Use the General tab to view and modify the properties, for example, priority order if necessary.
  4. Use the Criteria tab to view and modify the Criteria Expression if necessary.
  5. Use the Action tab to view, add, modify, duplicate, move, and remove other actions if necessary.
  6. Select OK.
Default RuleSets
The Default RuleSets specify the following parameters.
Accessing Default RuleSets
To access the Default RuleSets
  1. Select RuleSets > Default. The details pane lists the Default rules created when you installed the server.
  6. Select OK.
Note: You can also create custom User RuleSets or modify or delete existing rules, as needed. For information on how to create a new custom rule, see User RuleSets.
About RuleSets
About User RuleSets
