About iManage Extensions
HP CR enables iManage users to import hard copy documents into WorkSite libraries. The process is driven from the native WorkSite user interface screens and menus. Based on a user-selected format, the server converts scanned documents into text-searchable format (PDF or DOC), and then saves the resulting document into the proper WorkSite library, fully profiled and stored alongside other electronic content. Once imported, you can browse through libraries to locate these documents or use WorkSite enterprise search capabilities.
Creating a Routing Sheet using FileSite
Creating a Routing Sheet using DeskSite
Sending a document directly to the Server
