Sending a DeskSite or FileSite Document
You can use DeskSite or FileSite to send documents directly to the server.
  1. Open DeskSite. Or, open Microsoft Outlook and locate FileSite in the tree view.
  2. Go to the document library where you will send your document.
  3. Right-click on the document of interest and select Send to HP CR for iManage.
  4. The HP CR Client offers two options:
  • AdvancedHP CR Client opens to the New Distribution screen. The Attachments section contains recipient information from the profile. You can select any recipients necessary. Then Save the job as a new Distribution, or Send the message to the server for processing.
  • Send using Existing ReservationHP CR Client displays a list of distributions in the My Distributions screen. Select any job from the list and click Send, delivering the message to the Server for processing.
Save the job as a new distribution or Send the message to the server for processing.
About Extensions for iManage
Creating a Routing Sheet using FileSite
Creating a Routing Sheet using DeskSite
